06-14-2016 09:17 PM
Hello,
I am one of the consumer of Canon EOS 1200D with EF 18-55 MM Kit. I noticed that it doesn't have an audio input. However, I like to record audio from my mixer and video from my DSLR simultaneeously without video editing. Is there a way to add an audio input to the camera?
Thanks
06-15-2016 05:32 AM
Negative. You must record your audio separately, and then use video editing. Use a digital slate to sync audio and video.
06-15-2016 05:32 AM
06-15-2016 05:34 AM
06-15-2016 05:37 AM
Is connecting a 2.5 mm jack to the remote connector allows me to record audio and video simultaneously? Thanks
06-15-2016 05:40 AM
@Anonymous12 wrote:Is connecting a 2.5 mm jack to the remote connector allows me to record audio and video simultaneously? Thanks
Negative. There are no audio inputs associated with that connector on a T5. None.
06-15-2016 05:42 AM
Ok, Thanks for the helpful response.
06-15-2016 07:16 AM
Actually, come to think of it, you will record audio and video simultaneously. Audio will be recorded by the built-in microphone.
06-15-2016 09:49 AM
This is the second time recently that this bit of misunderstanding has popped up. Where do people get this idea?
06-15-2016 10:14 AM
@kvbarkley wrote:This is the second time recently that this bit of misunderstanding has popped up. Where do people get this idea?
The plug connector is identical to that typically used for a microphone input, stereo or mono.
06-15-2016 10:27 AM
I know, but even if I thought you could randomly stick 2.5mm plugs into any 2.5 mm jack and have it work, I would think "headphone", not "microphone"
