04-15-2016 04:12 AM
I have a Celestron 5se + canon 650d. They are mated with the celestron t-ring and the 93625 t-adaptor.
I want to take magnified photos of planets with the camera. But if I add an eyepiece to the t-adaptor, everything gets blur.
Here are some scenarios that highlight the problem:
1. look at Jupiter with 25mm eyepiece in telescope: clear and focused image
2. look at Jupiter with 6mm eyepiece in telescope: clear and focused zoomed image
3. look at Jupiter with camera and no eyepiece inside the t-adaptor, in telescope: clear and focused image but small.
4. look at Jupiter with camera and 6mm eyepiece inside the t-adaptor, in telescope: large unfocused ball
I dont know how to solve this.
Clearly, the 93625 t-adaptor was made to accept an eyepiece and lock it with the thumbscrew, but why does it not result in focused images?
04-15-2016 08:58 AM
The focal length may be too short. The T-mount does not guarantee everything will work. It only allows you to mate them together.
04-15-2016 09:31 AM
The set up I have REPLACES the eyepiece rather than attaches to it. It was originally bought in an FD mount but I was able to buy an EF adapter for it but I just have a cheap telescope.
04-17-2016 09:01 AM - edited 04-17-2016 11:43 AM
I just visited a popular online photo/video store, B&H. I assume that you are using the Celestron NexStar 5 SE. I am not certain if you have the correct camera adapter. B&H currently lists a different model number, 93635-A, camera adapter. The image of the adapter posted at B&H shows different marking on the barrel than yours.
" First, remove the eyepiece. Next, attach the SLR camera adapter where the eyepiece would normally be attached to the telescope, and screw in a t-mount adapter to the opposite end of the SLR camera adapter. Now you can attach your camera to the t-mount and you are ready to begin taking pictures! "
The above quote is from the product description of the adapter. The camera adapter is used in place of an eyepiece, not in conjunction with one. I would advise consulting Celestron, or even B&H, for better advice and guidance.
04-17-2016 10:39 AM
That's how mine works. The camera replaces the eye piece.
04-17-2016 11:42 AM - edited 04-18-2016 02:36 PM
@cicopo wrote:That's how mine works. The camera replaces the eye piece.
That's good to know. The OP has a generic camera adapter, which mounts onto an eyepiece, instead of the one made specifically for his telescope model. Maybe an extension on the T-adapter could "fix" his generic one. Who can say? But, the model specific adapter costs nearly the same as an extension.
