04-14-2020 09:56 PM
Hi everyone,
I need to take macro clean shots for hand wristwatches from my Canon EOS Rebel T3 with Lens EFS 18-55mm Lens. I need guidance on camera settings. I tried myself but shots coming out not clear what I am expecting it to be. I would really appreciate any help.
Thank you so much.
04-15-2020 05:50 AM - edited 04-15-2020 05:50 AM
Shoot in AV or manual mode with a small aperture probably about f11, side lighting to avoid reflections or bounced external flash gun pointed at the ceiling above but the best results will be obtained with a proper macro lens.
04-15-2020 09:13 AM
You will be much farther away than you want with that lens. You will have to crop. Set the lens to 55 mm, and manual focus. Move the camera back an forth until you get hte image in focus. That will be your maximum magnification.
You might want to invest in an EF-S 60mm macro lens.
04-15-2020 09:42 AM
You will not get very sharp product photos with the kit lens. Pick up a real macro lens, like the suggested EF-S 60mm.
For best results, you will want, actually need, to perform some degree of post processing of the images. Learn how to do non-destructive editing of your images. I do not mean converting RAW to JPG, something which you should always do. I mean literally retouching or recreating your images. Creating a pure white background is done in post, and not so much in camera.
04-15-2020 11:14 AM
"You will not get very sharp product photos with the kit lens. Pick up a real macro lens, like the suggested EF-S 60mm."
Even with that lens your results will not be perfectly clear. Meaning in sharp focus. You need to either take a Photoshop course or dive deep in to the PS manual. But the bottom line is you need to post edit. I would rather use PS and a poor lens than have the best macro lens and no PS.
