01-13-2016 07:39 AM
01-13-2016 08:31 AM
$500 is too low, but here is a reasonable beginner set for $600.
Canon refurbs come with a 1 year warranty, just like a new camera.
01-13-2016 11:02 AM
"Budget is tight, about $500."
Yes that is a little tight. Save a bit longer or try the Canon referb store as per suggestion above. But the Rebel to get is the Canon EOS Rebel T6i DSLR Camera with 18-135mm Lens. It will stay with you for a long, long time. This Rebel has all the current featuers of any Rebel.
01-13-2016 02:11 PM - edited 01-13-2016 02:12 PM
I'll echo ebiggs on the T6i. It is not just the most current Rebel, it is also the first major model-to-model improvement in Rebels since the T2i replaced the T1i. Autofocus in particular is vastly improved vs the T5i.
01-14-2016 10:32 AM
01-14-2016 11:15 AM
http://www.the-digital-picture.com/Reviews/Canon-EOS-Rebel-SL1.aspx
01-14-2016 11:22 AM
"What are your opinions on the rebel SL1?"
IMHO, it is too small for me. I am 6'3" and 220lbs. Are you a smaller person? If so you may like a Rebel SL-1 but I would suggest you try one first. I use some pretty large and heavy glass which is another reason I wouldn't buy an SL-1.
This is personal opinion and you should really try one.
01-14-2016 09:30 PM
01-18-2016 01:53 PM - edited 01-18-2016 01:59 PM
If you don't mind buying an used camera/lens combo, you can find a T2i/T3i with kit lens in your local market asking around $250- $300. Then spend some $$ buying a 50 1.8 STM for portrait/low light photography.
T4i has touch screen features but you may have to pay a little bit more. May be $400. Then you have $100 left for a 40mm F2.8 pancaske lens.
If you only shoot stills, you have a lot of choices with your $500. May be you can consider a Canon 40D($200) or even a FF 5D(350). They produce very very good images if you put on a decent lens.
BTW, you may spend $50 or less buying a vintage manual lens e.g. Helios 44-2 55 F2 and an adapter to use it on a crop sensor camera (not on the 5D - mirror crash). It's a lot of fun.
01-18-2016 04:41 PM
I noticed one of your uses is "pictures of boyfriend surfing". Be VERY careful near salt-water. Salt-water will kill the electronics.
We've had a few bad stories of people who wade out into the water -- or just get too clsoe and a big wave comes crashing over them and that's the end of that camera.
It is possible to get completely waterproof "underwater" housings -- but those are expensive for a DSLR.
