Reply
Occasional Contributor
Help Canon600D
Doe aan astrofotografie al een tijdje. Plotseling zijn mijn Isowaardes tussen 100 en 6200 te donker (zelfs overdag donkere foto's) Alle instellingen gebrobeerd en zelfs fabrieks instellingen ingesteld. Alle persoonlijke instellingen gewist.
Het vreemde is dat hij bij filmen wel genoeg licht geeft. Ik kan niet vinden wat het probleem is. Help? DAnk U!
Honored Contributor
Re: Help Canon600D
Hi Marianp. This is Canon USA user forum. Looks like you have written in Dutch. If you can repost in English we can try to help.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LR Classic
Re: Help Canon600D
Thank you
I hads lots of fun with my Canon 600D with night- and astro fotography. Recently however I cannot change between 100 and 6200 ISO. It's stays very dark and for me these differences are very needed when fotographing through my telescope. While I was trying changing all the settings I once had a H added to my ISO  that worked, but only very light. I tried all the settings and even erased all settings to firmsettings etc. etc. Nothing works. The funny thing is that while filming I do get enough light.
I so hope you can help me. As I cannot afford another camera
Thank you in advance,
Marian Pontier
Holland
VIP
Re: Help Canon600D
Marian,
You did reset to Canon factory defaults?  Beyond doing that with out success, I believe the camera is broken. Remove the battery for an extended amount of time.  Like a week, or longer, for instance and see if it completely resets.  I don't believe there is a 'keep alive' battery in a T3i Rebel.  If there is remove it also.
The 'H' is a pushed ISO setting.
VIP
Re: Help Canon600D
What is the position of the shooting mode dial on the top of the camera?  You probably want to use M, manual mode.
Honored Contributor
Re: Help Canon600D
Do you mean it is stuck at 100 or just that you can't get to 6200?
Re: Help Canon600D
Thank you for your reply. I will  try leaving out my battery as you advise me, not being able to use my camera terrible but necessary.
Hope it works
Thanks again
Marian
Re: Help Canon600D
I can switch from 1oo to 200 till 6200 but my camera it does not get any lighter. At one point (I don't know how I did that) I got a H (high ISO) that gave me more light, but I want to switch between different ISO's when I do my astro photo's.
For reason unknown The H after 6200 ISo dissapeared again.
VIP
Re: Help Canon600D
There may be a menu setting that enables and disables whether or not the "H" setting is available.
Honored Contributor
Re: Help Canon600D
See your manual and check Custom Functions.
powered by Lithium
