12-12-2018 04:28 PM
.I am an activities director at San Juan Assisted Living. I have used my Canon Rebel XS for years....its been good to me as an amateur photographer....during this time my lenses got damaged and I came across two Minolta AF lenses...to my surprise they didn't fit....so I got an adapter but the auto-focus stopped working with the adapter...do you know of any advice on how to make it work with this AF type lenses?
12-12-2018 05:55 PM
Minolta AF lenses when using an adapter on your Rebel XS does not have autofocus because the AF function on the lens works with Minolta film AF-motor cameras only, not Canon cameras.
What native Canon lens did you own prior to damaging it?
Try calling Canon's customer service and they will repair or replace the lens for you.
1-800-652-2666
12-13-2018 09:38 AM
I just put this Ford part on my Chevy and it doesn't work what could be wrong?
This is essentially what you are asking. Only Canon EF or EF-S lenses or third party lenses designed for Canon will auto focus.
12-13-2018 09:51 AM
I know it makes sense the way you say it like that.....Just of course Im an amatuer and saw the lenses and jumped at the ball for the low price. My mistake....well they work great with the adapter just need to learn my maual skills. Thank you so much for the response
@kvbarkley wrote:I just put this Ford part on my Chevy and it doesn't work what could be wrong?
12-13-2018 10:41 AM
"...do you know of any advice on how to make it work with this AF type lenses?"
Not only AF won't work but nothing except looking through it will work. It is a bad idea all the way around. You are far, by far, better served buying a Canon or a used Canon ef/ef-s lens. A used ef 50mm f1.8 lens can be had for less than $50 bucks. Sometimes very much less than $50 bucks and it would be lightyears better than what you are trying to do.
12-13-2018 01:12 PM
12-13-2018 03:52 PM
...and I have no idea how you would adjust aperture. You just might be stuck with using one aperture setting all the time.
Most vintage MF lenses have an aperture ring to adjust the lens' iris. And the Minolta AF lenses have an electronic aperture mechanism like EF/EF-S glass.
12-13-2018 09:14 PM
@AndyMilnePhotog wrote:...and I have no idea how you would adjust aperture. You just might be stuck with using one aperture setting all the time.
Exactly, my point. If it will not electronically control autofocus, how is it going electronically control aperture?
12-17-2018 10:35 AM
Perhaps an electronic Minolta AF to EF/EF- S adapter, but I don't think there is one in existance at all.
12-17-2018 04:47 PM
"Perhaps an electronic Minolta AF to EF/EF- S adapter, ..."
I doubt that is even possible as Minolta lenses and Canon lenses don't speak the same language. A any rate it isn't worth the time and certainly not the expense to try.
