Reply
Highlighted
Occasional Contributor
Re: Flash is out of control. Too Bright. Washes out all photos.
Very Specific, thanks.  I cleared and reset all settings. Then I turned Exposure Compensation to -2.  It was at zero.
My test photos in full auto mode, still are washed out.  Will keep adjusting. Any other ideas?
Highlighted
I just tried all of your good suggestions.   Good practice but can't seem to removed the 'washed out' overexposed flash from shots closer than 8'-10'.   Your guidance has been helpful in navigating the features.  Yes, I'm learning, dammit!   Thanks for the reminder.  Now to mess with it.  This lens worked fine on my T1i and previous models so I don't think it is that. Any other suggestions are appreciated.  Thanks again.  The manual is traveling with me tomorrow!
Highlighted
Esteemed Contributor
If I'm reading this correctly you are using AUTO mode. In my experience it makes terrible decisions compared to PROGRAM mode so try that first & see how the 2 compare. I just tried downloading the manual but for some reason it's showing up as blank pages but I'll try again from a different site, but the specs say you have +/- 5 stops of EC available & +/- 2 stops of Flash Exposure Compensation which is the one you need to play with now, but you may be able to combine BOTH (worth trying too). Another thing to try is the different metering modes & lower ISO's. It's not very often that we complain about to much power from the built in flash so I suspect it's just a matter of hitting the right settings.
Also until I download a manual check what speeds you can use while using flash. Many Canon bodies can use up to 1/200 which will cut the light way down compared to 1/30 sec.
Highlighted
OK, I've downloaded the manual from the US site & AUTO mode is even worse than I expected. You have no real control of the shot in AUTO. Things to read were on Pg 61, & 88 (Auto Lighting Optimizer note) but more importantly read vertically down the lists of what can be changed in AUTO & PROGRAM modes in the charts on pages 210 & 211. If I'm reading that chart right you CAN'T change Ec or FEC or the Sync speed or the ISO.
Highlighted
Thanks for directing me so specifically.  I did all of those things but it didn't seem to resolve it.
Not sure what to do next.  I'll keep reading and hoping.
Highlighted
Thanks for staying with me on this one.  Yes, it is difficult.  I have always had adequate results wtih AUTO on my other camera's and for pedestrian use, it has been fine.  I'll try adjusting through the other suggestions you mentioned.  My 'in flight' homework.  I'll share my findings.  I'd like to get it to work in SOME mode!
Highlighted
Respected Contributor
Try changinging metering to spot metering so it exposes for the subject and not the average brightness of whole scene.
Scott
Highlighted
According to the manual the camera sets all of these things in AUTO mode & they can NOT be changed or fine tuned by the user.
AUTO ISO, Standard Picture Style, Auto White Balance, Auto Lighting Optimizer, Long Exposure Noise Reduction, AI Focus, Auto AF Point Selection, AF Assist beam, Evaluative Metering, Single Shot, Auto Flash & sRGB color space.
The USER has the option to select the file size (or quality), red eye reduction on or off, timer, live view and Periferal Illumination Correction.
In PROGRAM mode the user can adjust just about every thing the camera can do.
Also from what I'm reading I'd say that also applies to using a flash mounted to the hot shoe.
Highlighted
Please get out of Auto.
There is a free 3- minute video tutorial on any camera subject on Google Videos.
Scott
powered by Lithium
