07-28-2016 12:25 AM
I do eBay listings for someone. When I am out of town, someone else needs to take pictures. So, we purchased a Rebel T4i at a pawn shop (barely had 1,000 shutter activations on it). It needed a flash, as the conditions in the warehouse are not always optimal for taking pictures.
So, we acquired a 430EX flash. The problem is that no matter what position the flash is in, the pictures are always washed out. We have a cheap Bower SFD35C flash that we were using with it (cost about $30). It does an okay job, but doesn't light up the items enough (they are kind of dark, but never washed out like with the 430EX).
The camera that I personally use for taking the pictures is a Sony Alpha A65 with an HVL-F58AM flash. I keep the flash angled one click backwards and the pictures always turn out fine. Since I do not have experience with the Canon cameras, can anyone guide me as to setting up the camera and the flash to work together?? I am actually beginning to wonder if the flash is defective (it was purchased used), since once I take a picture, I can no longer adjust any settings on the flash until I turn it off and on again.
If anyone has any ideas or pointers, your input will be greatly appreciated. Thanks in advance.
08-03-2016 07:37 PM
I asked the warehouse guys to take pictures of a few different items today, but they didn't listen. So, I only have a couple of pictures of the same item. Unfortunately, these pictures aren't nearly as bad as the ones in the past. I will have them take some more tomorrow, so that we can see a few different items.
08-04-2016 10:54 AM
You have a reflective surface. You will need to get an extension cord to move the flash off camera or get two flashes at 45 degree angles. Or rig up a sheet as a soft box.
