07-08-2020 01:57 PM
I left my camera with a friend over the weekend, I think he must have dropped it but he's insisting nothing happened. Anyway, the camera turns on but takes much longer than usual. I can't switch between modes unless I pop the battery out or else it will stay black and won't focus or take photos. When trying to film videos it won't focus at all and I have to focus it on a different setting before switching back. The flash was acting a little odd too.
Any ideas about what was knocked off-kilter or what I can do to fix it? Where can I take it during lockdown so someone can look over it?
07-08-2020 02:11 PM
First, use the wrench menu to return it to factory defaults.
07-08-2020 07:48 PM
I did that and now the screen won't light up no matter what setting it's on?
07-09-2020 10:03 AM - edited 07-09-2020 10:05 AM
Hit the info button. Reseat the eyecup, there is a sensor that turns off the LCD when your eye gets close.
07-09-2020 12:45 PM
@kvbarkley wrote:Hit the info button. Reseat the eyecup, there is a sensor that turns off the LCD when your eye gets close.
I don't think my T5 had a sensor. It is probably a bad memory card.
07-09-2020 12:47 PM
@Bookiecat wrote:I left my camera with a friend over the weekend, I think he must have dropped it but he's insisting nothing happened. Anyway, the camera turns on but takes much longer than usual. I can't switch between modes unless I pop the battery out or else it will stay black and won't focus or take photos. When trying to film videos it won't focus at all and I have to focus it on a different setting before switching back. The flash was acting a little odd too.
What happens when you remove the lens? Check the memory card. Is it the same card?
