Reply
Occasional Contributor
EOS 750D Movie Mode random auto focus adjustment
Howdy,
I have a 750D with Tamron SP 24-70mm lens
While shooting video, the camera suddenly re-focuses creating a white out or a black out for 1/2 second
Here are two examples of problem.
https://youtu.be/_ilV-dM5x6w
https://youtu.be/ISYRZ8teky0
I have tried a range of solutions - turned off auto-focus on camera and lens, set white balance to indoor, reset the camera.
It does not matter what location or light settings I am in, this keeps happening
Can anyone please tell me what causes this and how to fix it
Thank you
Esteemed Contributor
Re: EOS 750D Movie Mode random auto focus adjustment
Do you have a canon lens you can try?
Have you had any issues with the shutter button? This should only happen when the button is pressed half way.
Thanks for the reply KV,
Unfortunately I dont have another lens to try. I will see if I can borrow one from somewhere and try that.
Ive had no issues with the shutter button.
VIP
What shooting mode are you using? Test in Manual.
Thanks for the reply Wadizzle,
yes, set up in manual. Following this set up - https://youtu.be/fYVHbBkArJA
VIP
I suspect that you might be seeing the effects of light flicker.  Test it with different lighting types, like outdoors on a sunny day.
Which raises the question, is it the mirror flipping up that causes the black-out? Do you hear it? That is the assumption I have been working on.
Reputable Contributor
If it were light flicker related, wouldn't it happen at fairly regular intervals? Like every 10 1/2 seconds or every 2 minutes and so many seconds? I wonder if changing the frame rate would have any effect, or verify or eliminate the problem?
It almost looks like the on camera flash is sending out a short focus-assist flash. But I doubt the camera would do this in video mode, or that he even has the flash popped up and powered on. The lighting is pretty challenging in the second video but I don't see that as a reason for this kind of behavior from the camera.
In some ways it looks like a flash of light but then it also seems like the sensor acting up and affecting the whole screen. And that also doesn't explain the sensor "blacking-out" on occasion.
Thanks for the thoughts BurnUnit.
The problem does not occur at consistent time intervals. I have looked at different ways of triggering the "adjustment". I have filmed in different light (indoor and outdoors), and under different lighting conditions (natural light and studio). I have filmed static objects and dynamic (me) and there is no pattern to the "adjusment" occuring.
I changed the frame rates as you suggested as well as changing the image quality and the problem still occurs.
I am using a ScanDisk Extreme SD card (90mbs - Class 10) which should be sufficient for capturing data
The flash has not popped up.
I am trying to track down a basic canon lens to see what happens
So, does the mirror actually flip?
powered by Lithium
