Reply
New Contributor
Canon t5 rebel eos won't turn on
I have a canon eos t5 rebel and recently I recorded prom and now the camera won't turn on. I have tried charging the battery to see if that's the case it didn't work. I tried to change the battery it didn't work. Is there anything knows that I can do I kinda need it soon as possible anybody know the reason why it is acting this way please respond ASAP
VIP
Re: Canon t5 rebel eos won't turn on
It is always possible that you have a battery issue: not holding a charge; not making good electical contact because of bent pins on the battery,or in the camera; obstruction in the battery compartment, etc.  Your power switch could be faulty.  There could be some issue with your memory card, too.
You should get it checked by a professional, as soon as possible, if the problem continues.  Meanwhile, I would recommend that you remove your memory card, and try to recover pictures by reading the card with a computer.  Do not re-insert it into the camera.  If you have a spare card, try that in the camera.
Still, get your camera checked by a professional.  Call 1-800-OK-CANON.
Respected Contributor
[ Edited ]
Check the micro switches at the battery door and the memory card door.
DCS 3c, DCS 520, D30, D60, 1Ds, 300D, 30D, 1000D IR, 7D, 6D, 6D, M5
15-45/3.5-6.3 IS, 16-35/4 IS, 22/2, 24/1.4 II, 24-105/4 IS, 50/1.4, 50/1.2, 85/1.8, 85/1.4 IS, 100/2.8, 70-200/2.8 IS II, 300/2.8 IS
powered by Lithium
