12-05-2013 04:01 PM
Hello! I am new here and would like to know if the Canon Rebel XT lenses have the same mounts as the lenses for the T2i? Thank you!
12-05-2013 04:27 PM
The bodies have what's known as an EF-S lens mount (both bodies you've named) which take both EF & EF-S lenses so yes lenses you've used on the XT fit perfectly on a T2i
12-05-2013 09:44 PM
Yes, the mount is the same and both cameras also use "APS-C" size sensors. All lenses which work on an XT will also work on a T2i.
You can use every lens in Canon's current lineup EXCEPT the two "EF-M" lenses at the very bottom of the list:
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
In addition, even discontinued EOS lenses will work, as well as a fairly large number of 3rd party lenses designed for use with Canon EOS bodies.
When you use a Canon DSLR with an "APS-C" sized sensor (which is the vast majority of them... all the Rebels, all the mid-level cameras, and the 7D -- the only cameras that are not "APS-C" are the cameras with just 1 number in the model (e.g. 6D, 5D series, and 1D series) you can literally use any EOS lens *except* the "EF-M" lenses (and currently there are only two). The "EF-M" are for Canon's "mirrorless" cameras (not DSLRs).
