09-27-2017 07:22 PM
i am using a T5i camera and LP-E8 Battery and its original Charger.
I have been having low battery indicator on the camera for a while. I changed to a OEM battery, no respite. I change the charger thinking the charger is not charging it to full capacity, still no respite.
This is what it looks when I pop in a "Fully" charged battery in my Camera
I have no idea what setting is casuing and who is the culprit, Camera , or the Battery
T
What should I be looking at as the next steps
09-27-2017 08:14 PM - edited 09-27-2017 08:15 PM
What I see is that the battery is selected in the Quick Menu screen, and the selection square is red. What happens to the color of it when you move to other menu choices?
What happens when you re-select the battery and press [SET]? The camera seems to be trying to tell you something.
09-28-2017 09:08 AM - edited 09-28-2017 09:11 AM
The battery indicator is showing full charge.
09-28-2017 11:22 AM
09-28-2017 11:38 AM
It shows battery OK.
The image is black on white.
Camera is white on black.
I have a T5i - you are OK.
People can save themselves a lot of grief if they just read the camera manual.
02-23-2019 09:54 PM
I replaced the battery with a generic one on-line. After fully charging and inserting the battery the low charge and blinking image appears on the screen. Thinking that it might be the generic battery I purchased a I bought a new Canon battery and after fully charging the same blinking low battery image appears. Is this a problem with the camera or the charger? The camera is 2 1/2 years old and has worked fine until now.
02-24-2019 09:21 AM
@CanonVictoria wrote:I replaced the battery with a generic one on-line. After fully charging and inserting the battery the low charge and blinking image appears on the screen. Thinking that it might be the generic battery I purchased a I bought a new Canon battery and after fully charging the same blinking low battery image appears. Is this a problem with the camera or the charger? The camera is 2 1/2 years old and has worked fine until now.
You could have a charger problem. Are you using a Canon charger,, or a generic one?
Battery chargers deliver charging current a fixed rates. Batteries are designed to have charging currents delivered a fixed rates. When you start mixing up charger and battery brands, you can wind up with mismatches.
When the charger delivers more than the battery can handle, the battery may heat up. When the charger delivers less than the battery requires, the charger may start heating up, or even stop charging. In this latter case, it may appear that the charger has completed a charging cycle, when in reality is has simply shut down early to protect itself.
02-24-2019 10:01 AM
I am using the Canon charger that came with the camera. I will take the battery in to the store. If they find that the battery needs charging it looks like I will need a new charger. If they find that the battery is fully charged the problem will be with the camera.
02-24-2019 10:47 AM
It would be best if you brought all 4 into the store, the batteries, charger, and camera.
02-24-2019 11:16 AM
That is what I was planning to do. Stay tuned.
