12-09-2016 08:41 PM
I have configured my Canon EOS T6 WiFi to enable NFC, I have also connected my phone to the camera and the Cannon Connect app using WiFi.
However, with the NFC/Bluetooth turned on on my phone, and the NFC enabled on the camera, when I touch my phone to the camera, nothing happens. The app does not load on my phone, the camera does not show any connection.
I've seen all the videos online, I've read your manual, I've tried the help forums - I have seen no solutions. Is my camera likely defective?
12-10-2016 09:11 AM
I suggest that you try to contact Canon Support. Maybe, they can walk you through it. I know there are limitations associated with NFC. For example, I don't think that you can transfer RAW files via NFC, just JPEGs.
12-12-2016 11:19 AM - last edited on 12-12-2016 11:41 AM by Jenine
It's a <Removed Per Forum Guidelines>. I have to remove the camera from the tripod to get the little hot spot aligned with the corresponding spot on the Samsung Galaxy. The "touching" BS in the product literature is a farce.
12-12-2016 11:45 AM
@ardi wrote:.... I have to remove the camera from the tripod to get the little hot spot aligned with the corresponding spot on the Samsung Galaxy. The "touching" BS in the product literature is a farce.
Why do you need to remove the camera from the tripod?
The NFC "N-Mark" is on the side of the camera. This is where you should "touch" your NFC device to the camera.
12-13-2016 01:25 AM
I should have been more clear which camera I was talking about. The T6s "N" spot is on the bottom of the camera. There is no way to get a smart phone there when the camera is on a tripod. Some tripods with a large quick release foot even require rmoving it when NFC connecting. Poor design IMHO
12-13-2016 02:43 AM
I don't use the built-in wireless to transfer photos. It's far too slow for my average shooting day, which is hundreds of photos.
12-13-2016 07:53 AM
@Waddizzle wrote:I don't use the built-in wireless to transfer photos. It's far too slow for my average shooting day, which is hundreds of photos.
To put it another way, the camera's designers probably didn't imagine that a photographer serious enough to use a tripod would care where the "N" spot is.
06-02-2019 02:27 AM
06-02-2019 11:01 AM
@MayraMDelgado wrote:
Can someone help me connect my rebel t6 to the va.era app
What is that? If it is an app that is not released by Canon, then you may be in the wrong place to find assistance.
