‎11-14-2016 12:08 AM
‎11-14-2016 12:13 AM
Have you done everything that the manual tells you to do to get started? A wild guess would be that you need to format the card.
‎11-14-2016 12:49 AM
‎11-14-2016 03:13 AM
I'll bet it did.
‎11-14-2016 07:46 AM
@emilycopeland wrote:
Format the card ?! The manual said nothing about that 😂
It is strongly recommended that you do not use a micro-SD card with an adapter in your camera. The adapters seem to have intermittent connections between the camera and the card.
‎04-03-2017 12:28 PM
I also use the Rebel T6. You will be doing yourself a huge favor by spending some time with the manual. Download the full Instruction Manual.
On Page 5 it states:
"If the card is new or was previously formatted by another camera or computer, it is recommended that you format the card with this camera (p. 52)"
On page 5 it also lists compatible cards.
‎11-14-2016 10:02 AM
‎11-14-2016 10:17 AM
So then what shall I use 😩 Never had this problem with Nikon. Only reason I switched is because Canon is supposedly better quality
You should use a full-size SD card. What does the card you're currently trying to use say on it?
‎11-14-2016 10:26 AM
As Robert said, only use a full size card. I'm pretty sure that your manual makes no mention of "micro-SD cards". I'm certain that the manual only mentions "SD/SDHC/SDXC memory cards."
Only use micro-SD cards in devices that are designed to use them directly, without an adapter.
‎11-14-2016 10:52 AM
You really should spend some time with the manual, but at least here's a start.
https://www.youtube.com/watch?v=7UmDtw7eKyk
