05-12-2020 06:45 PM - edited 05-12-2020 08:07 PM
I have an EOS Rebel T5, and I am using HDMI output to stream video. I do not want the auto-focus box from the HDMI output.
I put it into Live mode so it's doing face detection, but the problem is that there are faces, so the box jumps around. I also tried the trick of flipping the camera upside down to "trick" the face detection, which actually works, but feels super hacky.
I also tried setting the lens to "MF" instead of "AF", but that made the focus box for me even bigger.
Are there other solutions for this problem that I haven't tried yet.
05-12-2020 06:59 PM - edited 05-12-2020 07:08 PM
@Creakudoor wrote:I have an EOS Rebel T5, and I am using HDMI output to stream video. I do not want the auto-focus box from the HDMI output.
T5? Nonsense.
05-12-2020 07:26 PM
@Waddizzle, I'm not sure what you're saying? That it should work with what I tried? Or that it shouldn't work?
Yes, it's an EOS Rebel T5.
05-12-2020 08:25 PM
Creakudoor,
There is a button on the back of the camera marked Display (DISP.). If you press this, it will change the onscreen displays. Cycle through until you get the correct display to fit your needs.
05-13-2020 11:20 AM
@Tim, I tried this, and it does not solve what I am trying to solve. It cycles through showing different things on the screen or not, but ultimately does not hide the Autofocus box in the center of the screen.
05-13-2020 11:31 AM
It sounds like you're looking for "Clean HDMI Out?"
The T5 does not have this.
You can see the models that we currently recommend for live streaming here: canon.us/livestream
More models will be added to the EOS Webcam Utility as the software is developed, so we recommend signing up to be notified when your camera is supported.
05-13-2020 02:01 PM
Yes, sounds like that's what I need to do what I want.
Do you know if the T5 is on the consideration list to be added to this utility in the future?
