07-12-2018 03:48 PM
I have an EOS 200D (Rebel SL2) and would like to get an off-camera flash. I find conflicting information about whether my camera supports wireless flash or not. There seem to be different modes (optical vs. radio) and everything is a little bit confusing for a newbie. So here is what I found:
So all of that sounds like I would be able to use the 430EX III-RT over wireless, but some further googling revealed:
Can anyone clarify on this? Maybe someone has that camera+flash combination? Thanks!
07-12-2018 04:20 PM
@caslex wrote:Thanks for you reply.
From what I understood, optical transmission wireless flash is not the same as RT (radio transmission?) wireless flash though. Does the EOS200D/SL2 support RT? Or is my only option to buy another gadget (be it a flash with optical master capability or some radio transmitter device)?
AFAIK, no Canon camera is capable of being a radio master, so you'd need a second flash with RT capability (or a standalone radio transmitter) to serve in that role. Some Canon cameras can serve as an optical master, but yours is not one of them. So you'd need a second flash unit as the optical master. You just have to make sure that the master and the slave are on the same page (both optical or both RT).
03-06-2019 08:23 AM
03-06-2019 11:52 AM
If you have an android smart phone you might try an app called "Photographer's Companion". It has a simple light meter as one of the selections, while it is not going to be as good as a dedicated light meter it should get you close to the settings needed.
03-06-2019 12:28 PM - last edited on 03-06-2019 12:35 PM by John_B
Sekonic light meters are worth looking into, they've been around for a long time. The L-358 model can be had for around $100, used, working on auction sites with a wireless flash trigger like eBay. It can measure both incidental and reflected light and provide you with exposure settings in Tv, Av,Ev, Cine video and more, way too much to explain or list here. Don't get overwhelmed with its capabilities as it basically is just a point and shoot meter once you set the mode. Here is a link for that listing as well as the manual:
**Link removed per forum guidelines**
