02-02-2017 07:40 PM
Look in the card slot and see if there is anything that might be preventing the card from connecting. If there is, you can try blowing it out.
02-02-2017 07:43 PM
There is also a switch in the camera that senses thew card. If that is malfunctioning the camera won't know a card is installed. But it should give you a "No card" message on the LCD.
Give Canon a call at 1-800-OK-CANON.
02-02-2017 08:40 PM
@kvbarkley wrote:Look in the card slot and see if there is anything that might be preventing the card from connecting. If there is, you can try blowing it out.
Slot is clean
02-02-2017 08:41 PM
@jrhoffman75 wrote:There is also a switch in the camera that senses thew card. If that is malfunctioning the camera won't know a card is installed. But it should give you a "No card" message on the LCD.
It knows that the card is installed,it says it needs formatting,but when i format it tells me to get an other card
02-02-2017 08:43 PM
Does Thant happen with more than one card?
02-02-2017 08:46 PM - edited 02-02-2017 08:47 PM
@jrhoffman75 wrote:Does Thant happen with more than one card?
Yep
02-02-2017 09:05 PM
Need to contact Canon.
02-03-2017 04:00 AM
02-03-2017 06:47 AM
You could try this if you are comfortable with a little precision work. The stuck switch is sometimes a cause of not detecting a card.
02-03-2017 10:32 AM
@L3apr wrote:
Just as an idea,what may have gone wrong with the camera?
It is broken. Sorry to be snarky, but there is really no way to tell.
