02-02-2017 04:19 PM
The camera turns on without an sd in and when i use the sd the screen stays blank with no sounds from the shutter moving
02-02-2017 04:36 PM
Are you using a full size SD card?
02-02-2017 04:39 PM
Yes
02-02-2017 04:59 PM
What size card? If it is SDXC, 64 GB or higher, then "might" explain your problem. Despite what specs say, I have had trouble with T5, EOS 1200D, recognizing new SDXC cards until I format them in my computer, then reformat them in the camera.
Also, you could have a defective card. Buy a new card, 32GB or less. Stick to name brands like Sandisk or Lexar. Beware of bargain deals on the internet. Buy a card from a local retailer.
02-02-2017 05:03 PM
02-02-2017 05:50 PM
@Waddizzle wrote:What size card? If it is SDXC, 64 GB or higher, then "might" explain your problem. Despite what specs say, I have had trouble with T5, EOS 1200D, recognizing new SDXC cards until I format them in my computer, then reformat them in the camera.
Maybe a factory reset will do something?
02-02-2017 05:53 PM - edited 02-02-2017 05:58 PM
TEMPORARILY set the camera to allow shooting without a card installed. Remove the card. Set camera to Program (P) mode. Does the shutter fire?
Let us know what happens. Switch the setting back to "Disable". You don't want to take a bunch of photos without any "film" in the camera.
02-02-2017 05:58 PM - edited 02-02-2017 06:04 PM
@jrhoffman75 wrote:TEMPORARILY set the camera to allow shooting without a card installed. Remove the card. Set camera to Program (P) mode. Does the shutter fire?
It fires,it works normally as it should
02-02-2017 07:10 PM
02-02-2017 07:30 PM - edited 02-02-2017 07:31 PM
@jrhoffman75 wrote:
It must be a problem with your card. Try formatting in computer and then format in camera. Be sure the lock isn't on.
I tried,even with a 16 gig card,tried fat 32 and fat,still nothing
