Canon EOS 100D Not turning on with an sd in
L3apr
The camera turns on without an sd in and when i use the sd the screen stays blank with no sounds from the shutter moving
There is also a switch in the camera that senses thew card. If that is malfunctioning the camera won't know a card is installed. But it should give you a "No card" message on the LCD.
Give Canon a call at 1-800-OK-CANON.
21 REPLIES 21
Look in the card slot and see if there is anything that might be preventing the card from connecting. If there is, you can try blowing it out.
It knows that the card is installed,it says it needs formatting,but when i format it tells me to get an other card
Does Thant happen with more than one card?
Yep
Need to contact Canon.
Just as an idea,what may have gone wrong with the camera?
You could try this if you are comfortable with a little precision work. The stuck switch is sometimes a cause of not detecting a card.
It is broken. Sorry to be snarky, but there is really no way to tell.
There is definitely something wrong with the camera and/or cards being inserted into it.  Make sure the cards are properly oriented when you insert the,. I think you need to contact Canon U.S. Support at 1-800-OK-CANON.
Enter for a chance to win!
April 20th-28th
