Reply
VIP
Re: Canon 750D gets stuck and won't save image
[ Edited ]
@Brendahian wrote:
I will try to do that. What do you recommend i use for the SD card?
Where you purchase memory cards is just as important as what brand and type of card.
I recommend either of the two cards seen on the right, [except you want the 32GB version].  The one on the far left is low quality, which I would not recommend.
You stated above that the camera displays a message that suggested that it is recording multiple images to the card.  What sort of shooting are you doing that would cause that too happen.  Are you continuously shooting until the buffer is full?
Are you shooting in low light conditions?  Have you tried resetting the camera back to factory defaults?  You must be in P, Av, Tv, or M mode to reset the camera.
VIP
IMHO, 128GB SD cards are too big. It tends to make a person use their camera as a storage device which it is not. A better best practice is 32 GB SD cards. Hopefully that will cause you to change them so all your photos do not reside on a single SD cards. So, if there is a problem all is not lost. If you do buy 128GB SD card, buy several and change them so the risk of lose is reduced.
VIP
Yes, you are correct.  I had forgotten that image showed 128 GB cards.
I made the same recommendation to use 32 GB, or smaller cards on an earlier reply.  I wanted to show the difference between cards.  Some cards form major manufacturers are not suitable, like UHS-II cards, for example.
VIP
Great Smiley Happy
Occasional Contributor
No i am only shooting in single shot mode and not continuous and sometimes i use it in remote mode to shoot when im shooting myself. And i only shoot in Manual mode. I tried formatting the card on windows like you suggested and tried to shoot again and it did the same thing. I will try to use a new SD card with your recommendation and see what happens. Is there any possible reason as to why is this happening?
VIP
"Is there any possible reason as to why is this happening?"
Yes, it is broken. If the new SD card does not fix it call Canon 1 (800) 652-2666
BTW, you did do a full reset of the camera?  Yes, no?
Yes i reset the camera to factory settings multiple times it worked the first time but after that it didn't help.
VIP
Frequent Contributor
Are Lexar Professional 1000x 64GB SDXC UHS-II Cards OK to use?
Walter
in Davie, FL
VIP
"Are Lexar Professional 1000x 64GB SDXC UHS-II Cards OK to use?"
The UHS-II cards are not suitable for most Canon cameras.  They are definitely not suitable for use in an older camera like the 750D. Refer to your User Manual for the best cards to use in your camera.
powered by Lithium
