Reply
Highlighted
Occasional Contributor
Accepted Solution
Cannot format my sd card Canon Rebel sL1
I need help. I have a brand new ScanDisk ULTRA 64 GB sd card. I have looked up many forums and YouTube videos and tried everything but still get the message "Cannot format; change card". Please does anyone have any tips or tricks? Do I need to get a different SD card?
Highlighted
Reputable Contributor
Re: Cannot format my sd card Canon Rebel sL1
Hi JJ:
1st, have you had success formatting other cards, particularly high capacity ones? According to the SL1 specs it should be able to use SD/SDHCSDXC cards, so that would suggest it should.
2nd, Where did you get your Sandisc Ultra card from?  I see you have spelt it differently from the official manufacturer, is that just a typo or did you copy it from the card.   There are lots of counterfeit cards out there.
cheers Trevor
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"A good swordsman is more important than a good sword" Amit Kalantri
Highlighted
Esteemed Contributor
Is is a full size card or a micro card with an adapter?
Use a full size card
Highlighted
VIP
If it were "write protected" I would expect it to tell you so, but check the write protect tab, anyway.  It sounds like you may have a bad card.  BTW, I have never heard the brand "ScanDisk" before.  Is that a typo?
Highlighted
If it is not a typo for SanDisk, it is a clever counterfeit!
I really need to take the counterfeit products class at my work to see more of these.
Highlighted
Honestly folks I am so lost. This is a friends camara that is brand new and she has never used it. I am still a beginner and don't know how to tell at all the specs and if the chip I believe is full size. I went a formatted the card via my pc but I am still getting the same message through my camara. I was told that I may need to do a firmware update so I found that through the Canon website but there are 5 options that I dont know which one to use. They all say 100d_sl1_x7- firmwareupdate then they all have different last digits. -en, -fr, -jp, -sp, - zh. So I have no clue. The disk itself says SanDisk ULTRA 80MB/s. To the right side it has the SD logo with XC 1 then the C10 logo underneath that.
Highlighted
It was a typo.
Highlighted
the dash numbers are the language, english, french, japanese...
These are micro Sd's with adapters:
Full size looks only like the adapter.
Try a new full size card.
Highlighted
VIP
Those last digits are describing the default language the menus will use: English, French, Japanese, German, etc.  BUT, forget about doing a firmware update for now.  You may do more harm than good.  I doubt if that would correct the issue, whatever it might be, anyway.
Your memory card is the prime suspect, until proven otherwise.  Make sure that you purchase SD cards from a reputable source.  There are many counterfeit cards being sold on Amazon and eBay.  I recommend stopping by a Best Buy.
These are the cards that I use.  I have never had an issue with Sandisk FULL size SD cards.  I suggest that you go out and buy a new SD card from a local store.
Highlighted
VIP
@JJCamille wrote:
It was a typo.
I think you have this one.
powered by Lithium
