04-18-2013 05:45 AM
I have Cannon T3i Rebel body and now i wanted to buy a new lens. Does Canon EF-S 18-135mm f/3.5-5.6 IS STM Lens supports Cannon T3i Rebel?
Thanks
Praveen
04-18-2013 06:38 AM
04-18-2013 07:35 AM
Can you suggest me any better lens than Canon EF-S 18-135mm f/3.5-5.6 IS STM or this is the best in that segment?
Thanks,
Praveen
04-18-2013 08:22 AM - edited 04-18-2013 10:03 AM
I've personally been a fan of the EF-S 15-85 which is a great all purpose zoom for crop cameras like yours. It is a little wider but not as long in focal length. It has the same variable aperture range as the 18-135. The real benefits of this lens are its excellent sharpness and build quality. I would certainly add this to your list of lens to consider.
04-18-2013 09:21 AM
Hi mailpravinat!
Just to expand on what everyone is saying: the EF-S 18-135mm f/3.5-5.6 IS STM lens will physically mount to your EOS Rebel T3i, and the lens will auto focus in photo mode, however, in video mode the stepping motor will not function which means that the camera will not contuniously auto focus because the EOS Rebel T3i does not support the STM function of the lens.
04-18-2013 11:51 AM
@mailpravinat wrote:Can you suggest me any better lens than Canon EF-S 18-135mm f/3.5-5.6 IS STM or this is the best in that segment?
Thanks,
Praveen
There really isn't a 'best', as it depends on your needs and uses. Of course there are better lenses, but they cost more, usually have less range, and a bigger and heavier. Image Quality and large apertures are very important to me, so if I was shopping for a wide angle lens for a crop I’d get the 17-55 /2.8. It’s also a $1000 lens, considerably more than your 18-135. If you’re not going to shoot at f/2.8 then there’s little use in spending the money on a lens like that.
The 18-135 is inexpensive, light and reasonably small, and has terrific range making it a good all around lens for travel or street photography. The image quality isn’t going to match more expensive lenses with less range (in general, the longer the range the worse the IQ), but that doesn’t mean it’s bad. I think it looks like a good introductory lens for a modest investment that gives you a lot of range. If you find yourself needing better glass in the future then you’re really not set back all that much.
09-10-2016 07:25 PM
Hello Stephen, is any EOS Rebel support the STM function of the lens for auto focus in video?
09-10-2016 11:59 PM
Yes, STM is in the lens. But it depends on the camera as to how well it autofocus' during video. My T6S would be better in that regard than the T3i.
09-11-2016 09:29 AM
Thanks so much for the information Kvbarkley.
