03-14-2016 03:55 PM
Hi all,
I recently bought a T6i, a 64 GB SanDisk card, and an Optex card reader. I can take photos just fine, I can transfer the RAW images from the camera to my phone as JPEGs using the Canon Camera Connect app, but I can NOT seem to get the RAW images off the camera.
Whenver I use the card reader, I get a message saying the card has to be formatted (which I obviously don't want to do). It works fine with my older card, though. And I can't seem to get the T6i to connect with a USB cable (my previous Canon would automatically connect, so maybe there's a step I'm missing here).
I'm using Windows 10 on a PC, if that matters. Any ideas? Is there a way to transfer RAW images, not JPEGs, using the app?
Thanks,
-Trevor
03-14-2016 04:15 PM
Are you shooting RAW+JPEG or just RAW?
03-14-2016 04:21 PM
Just RAW.
03-14-2016 06:48 PM
@tcpritchard wrote:Hi all,
Thanks,
-Trevor
When you try to connect the camera or the card reader to the computer, are you using the same USB cable? If so, maybe it's the problem. Some cables don't have all the necessary conductors and are useful only for charging a cell phone or similar device.
03-14-2016 06:53 PM
Nope -- the card reader has its own USB connector, so it's different from the cord I'm using to connect the camera.
I was able to get the images directly off the card using a friend's Macbook, but it's weird that I can't get anything to work with my PC.
03-14-2016 07:35 PM
If you've safely transferred your RAW files onto the Macbook and you know they're intact, you might give this a try. Format the card in the T6i, not in your PC. Also set the camera's calendar and clock data. A lot of people don't bother to do this and usually they don't have any issues. But certain models of certain cameras can be a bit "fussy" about it and show strange behavior like you're describing. And the owner's manual for your camera probably recommends formatting the card in-camera and there's probably a reason why.
Have tried downloading RAW files using your older card in the new camera?
03-14-2016 10:16 PM
Thanks. I may have to try that and hope the card works afterwards. As for trying to download RAW images with my old camera's card, unfortunately, it was for a Rebel XTI and is much too big to fit in the T6i's slot.
03-14-2016 09:16 PM
I am not sure why you'd want RAW images on your phone. Unless there is an app I don't know about you wouldn't be able to view the RAW images on the phone.??? Are you running a mobile image processing program?
Every new Canon camera model comes with its own new version of Camera Raw. That is why you have to upgrade your Lightroom program to the newest version (or do a PITA work-around using DPP and making tiff files or something) if you buy a new model of camera after a newer version of Lightroom than yours is already out when the new camera was released. Adobe will only write a new RAW decoder for a new camera for its current version of Lightroom.
As as for just pulling the files off, just open two windows in My Computer (or the Apple equivalent thereof). Open the card reader in one to see all the files on the card. Open your storage file (hard drive, portable hard drive, whatever) in another window. Highlight all the files on the card. Drag and drop them into the storage folder. Simple, but also foolproof.
03-14-2016 10:20 PM
ScottyP, I only wanted the RAW images on my phone so I could transfer THOSE (not the JPEGs) to my PC. Which has Photoshop.
Unfortunately I can't pull the files off the way you've suggested (that's the way I normally do it) because no files show up when I plug in the reader. I'm only getting the message about formatting the card and can't seem to access the files on it. And they're there, because I can transfer them wirelessly (as JPEGs) to my phone.
03-15-2016 05:56 AM
I assume that you go into the camera's menus and change the settings when you switch between WiFi and USB, right?
