Reply
Highlighted
Frequent Contributor
Re: Camera saying busy and won't take pictures
Have you tried the solution that worked for some on this forum?
Class 10 quality card formatted IN the camera?
Fresh batteries that not only hold a charge but also charge up to capacity?
Do you get the same problem using different lenses?
Highlighted
Occasional Contributor
I tried memory cars, battery, change lenses, no help.  The camera was finally fixed with a new main board.
Highlighted
Thanks for the update. Glad you tried the alternatives first.
So sorry about the $$$ for the main board replacement.
That seems to be a consistent challenge with this camera according to some other posts.
Highlighted
@hannahcbettis
dot next to max burst # is the Focus confirmation light..  It lights when camera perceives auto focus has been achieved.
Mamiya Super Press 23, Minolta SRT 100, 101, & 102, Canon AE-1,
Rebel T5 EF-S 18-55mm IS II & EF 75-300mm f/4-5.6 III Kit Refurbished $260
As Seen on TV, It's Not for Me
Highlighted
My problem was fixed with a new main board for $280
Highlighted
[ Edited ]
My problem like this was fixed with a new main board for about $280 by Royal Camera Service.  [link removed per forum guidelines] I was very satisfied with their service and shipping and handling. Quick turn around also.
Highlighted
And I should add that the camera is still working fine 3 months later.
Highlighted
Glad you are back in the confidence that your camera is working and will continue to work as it should.
Happy Shooting! Thanks for the update.
Highlighted
New Contributor
But should we all be having to replace the main board?  this is my third Canon Eos rebel (one print, two digital) with which I have had the same problem.  Different batteries, different lenses.  I guess fie on me for buying the same camera over and over despite this but I like the way it operates when it's working.  I think maybe I should invest the money elsewhere rather than buying a new main board.
Highlighted
It would be very messed up if this is what technology leads us to...equipment that won't work and is not under any warranty.
I have not had any cameras fail and need to be repaired in 40+ years as a professional photographer around the world. Now my cars are another story.
Point being it may be the luck of the draw or ????  Your guess is as good as mine on this one.
Good luck.
powered by Lithium
