Reply
New Contributor
Accepted Solution
Busy message and Missing and distorted Pictures
Hello all,
I took about 200 pics at an event with my T3 last weekend. everything was fine for about 50 pics, I was able to see the preview of each pic at first, then something weired started happening:
1: The camera kept saying busy when I tried to take the next pic 2 or 3 seconds after the previouse one (one shot, not burst)
2: "no preview available" message would pop-up
3: After connecting camera to PC to import picsinto LR, I had over 100 pics that showed the image size, but the image was not there.
4. Some of the pics will show the image at first, but then add a multi-colored box to part of the pic making it useless. I know that the rest of the info for the pic is there because when I first open the pic it shows the whole image with that multi-colored box.
What I have done so far:
- Copied all images off of mem card and formatted card (low level format selected)
- purchased new mem card
- Updated camera firmware from 1.0.5 to 1.0.6
Other info:
- Shooting in RAW
- Samsung 64GB 10 microSD (inside adapter)
- Used this mem card in same camera for about 3 other shoot without a problem
Questions:
Is there a way to retrieve the image of the photos? It shows me the size of the file
Should I be using a FULL size SD card instead of the microSD with adapter
Any help would be appreciated!!
VIP
Re: Busy message and Missing and distorted Pictures
@Smythisiswrote:
Hello all,
Other info:
- Shooting in RAW
Questions:
Yes, that is your problem.  You should be using full size SD cards,  not microSD cards with adapters.  You should also stick to using SD cards that are 32 GB, or smaller.  Select your cards carefully.  Use cards that are similar to those that were available when your camera was first released.  Some of the newer cards are to advanced for the older technology.
VIP
"Should I be using a FULL size SD card instead of the microSD with adapter"
The thing about the micro SD is they work..................until they don't !  I would always stick with the SD card your manual recommends.  When you stray from what Canon suggests you run the risk of poor or no performance.
I will guess your shots are toast.  However, some SD manufacturers offer a recovery service so you might contact Samsung.
You might be able to d/l some recovery software and try it yourself.  Good luck.
Stick with what Canon recommends in future.
New Contributor
Thank you @waddizzle @ebiggs1
I'll be sure to go out today and get a SD card recommended for my camera.
powered by Lithium
