Reply
New Contributor
Blurry when using eye focusing
Hello,
We recently droped our canon 600d camera on a floor and since then is something wrong.
On lcd screen focusing as normal, but when i am using my eye to focus is blurry. Please can you help me? Is it easy to fix or i should tike to someone to repair.
Thanks a milion!!!!
Super Contributor
Re: Blurry when using eye focusing
Did you check the diopter adjustment on the viewfinder?  It may have just moved when the camera was dropped.
Honored Contributor
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
Respected Contributor
Yes I'll bet the little diopter adjustment wheel on the eyepiece got flicked in the confusion.
Scott
New Contributor
Thank you for quick respond. I checked that, i think is probably domething internal got loose or something.
If you are truly unable to dial in a clear view by slowly rolling the diopter wheel all the way through its range of motion while looking thru the eyepiece maybe your focus screen popped partly out.  That is the delicate little thing above the mirror. YouTube can show you how it is removed and replaced so you see where and what it is.
Scott
VIP
I, too, think it is a mis-adjusted diopter,  However, if the camera equipped adjustment wheel doesn't work there is a add-on accessory to increase the range.  Some of us need that extra.........help.  Check out the Canon Dioptric Adjustment Lens.
Honored Contributor
Dropping the camera is very unlikely to have affected the diopter wheel and much more likely to have dislodged the focus screen. Does the camera autofocus correctly in viewfinder mode? If it doesn't, the diopter wheel isn't the issue. The diopter wheel has no effect on autofocus.
Eddie, unless you're an experienced camera repairer, I don't think you should try to re-seat a dislodged focus screen yourself. "Delicate" is the operative word in Scott's explanation.
Bob
Moderator
[ Edited ]
Bob from Boston is giving sound advice.
If, in fact, it is a dislodged focusing screen (which it very well could be), this is something only a qualified Canon Factory Service technician should repair, as they are not user-servicable on Rebel (EOS XXD) model cameras.
At this point, we think it's a good idea to get in touch with technical support. If you're here in the USA, call 1-800-OK-CANON (800-652-2666) anytime from 8am to Midnight (ET) during the week, or from 10am to 8pm on Saturdays.
If you're outside the USA, CLICK HERE to select your country or region. You'll find support/contact options from there!
New Contributor
Re: Blurry when using eye focusing, T6i
 I am having trouble focusing through the view finder and I am not satisfied with the sharpness of my pictures. This applies to multiple lens and shots. I have obtained a +2 eye piece but still unable to get a sharp image through the finder.  My question is how do you determine which eye piece is correct with out trying each one. Is it based on magnification or something else.Thank you in advance
powered by Lithium
