07-24-2019 10:23 PM
07-25-2019 04:03 PM
07-25-2019 04:04 PM
07-25-2019 04:36 PM
No photo come out normal, properly exposed? No, your camera is broken, sorry.
07-25-2019 04:39 PM
Call Canon support. Keep in mind a used "working" T4i is worth about $250. That does not leave much room for repair if repair is even possible on a T4i. It may be out of service life.
07-25-2019 04:39 PM
07-26-2019 11:46 AM
@rql49 wrote:
I have a canon 4ti. When it is in auto mode or any other mode the pictures are over exposed. In the other modes I have to adjust the to have it under exposed by 2 or 3 stops. Any suggestions on how to fix it? I have cleared all the functions.
You're not addicted to fill flash, are you? One very effective way to achieve gross overexposure is to use flash in a scene so brightly lit that it needs a shutter speed faster than the sync speed. In such a circumstance, the camera won't use such a speed, even if you tell it to. (At least that's how it worked on an XTi when it happened to me; I've never used a T4i, but I suspect its behavior is the same.)
07-26-2019 01:45 PM
07-26-2019 01:54 PM
So it is the exposure system that is linked to the viewfinder. The camera needs repair.
08-05-2019 12:25 PM
It would be very bright indeed to prevent a correct exposure. My T6S can reach EV 23 and according to wikipedia, sand and snow in sunlight is EV 14.
