08-08-2017
03:05 PM
03:21 PM
wifi cards exist, to fit a CF type, apparently must use CF adapter for a smaller card. Here is one that will hold various SD cards.
[link removed per forum guidelines]
questions:
Will this work with the rebel xti?
Will some types of SD card not work with the camera?
tyvm in advance for any help
08-08-2017 04:28 PM
Smaller cards with adapters are usually a bad idea. If you really need WiFi on an XIi, get a full-sized WiFi card and use that instead. There used to be one; I think it was called the "Eye-Fi" card. I'm not sure they still make them, but you might find one on the used market.
08-08-2017 06:27 PM
There are a number of CF/SD card adapters on the market. As is true for many off-brand products it is possible that they are all made by the same manufacturer.
Eye-fi is now out of business. Toshiba makes SD wifi cards.
I don't think your camera is Eye-fi enabled, which means if you want to be uploading you need to keep the camera poered on until uploading stops. If you forget to switch camera never sleeps until battery drains. (An Eye-Fi enabled camera keeps power on until uploading stops and then switches back to whatever power off setting you have.)
If you want to go this route be sure you buy items that have a return in case it doesn't work.
08-08-2017 06:38 PM
Hi Charlie22,
Thanks for posting.
While some of our newer memory cards support "Eye-Fi" memory cards, for wireless image transfer, no such support is available on this camera model.
08-08-2017 04:28 PM
08-08-2017 06:27 PM
08-08-2017 06:38 PM
Hi Charlie22,
Thanks for posting.
