03-20-2023 11:23 AM - last edited on 03-21-2023 10:14 AM by Danny
When I look through the view finder the photo is blurry. It is find when I review it. How do I correct this? Manuel is no help.
Thanks
03-20-2023 11:59 AM
Hiya, Rachel, sorry you're having this trouble.
Your EOS R camera has a tiny black thumbwheel just to the right of the top right corner of the viewfinder eyepiece. That is the dioptre adjustment, it's for adjusting the viewfinder optics to match your individual eyesight.
If you wear spectacles, you need to decide whether you're going to look through the viewfinder while wearing your glasses, or will remove them. Some people find it difficult to see though a viewfinder eyepiece while wearing specs,but your EOS R is particularly good and I can see fine through my viewfinder with my specs on. While looking through the viewfinder, operate the autofocus (with the camera switched on, take up the first pressure on the shutter button to make the lens snap into focus) and then rotate the above mentioned thumbwheel and note that the image becomes sharper or less sharp. Turn it appropriately forwards or backwards until you have a nice sharp image.
It is possible to jog the thumbwheel accidentally, so if the image loses sharpness again, you may need to re-adjust the dioptre adjustment.
I hope this helps.
03-20-2023 12:52 PM
03-22-2023 12:09 PM
Oops - as glimpsed in the video linked above by Stephen, I note that the dioptre adjustment thumwheel on your EOS R camera is actually lower left of your eyepiece, not as on my R6mkII and I think most other Canon cameras, upper right. Sorry about that! I hope otherwise what I've suggested proves useful.
03-20-2023 11:39 AM
What camera are you using?
You probably need to adjust the diopter.
03-20-2023 11:40 AM
EOS R
Where, what is the diapter?
03-20-2023 11:59 AM
I hope this helps.
03-20-2023 12:52 PM
03-22-2023 12:09 PM
12-24-2023 11:56 AM
Thank you! My almost 2 year old nephew got a hold of my camera last night and we could not figure out why it was blurry in the view finder!!! The adjustment switch is actually completely underneath the viewfinder (it stick out from the camera some and there is a space on the bottom side of it). So glad the camera wasn’t broken we were all worried! Kids that age find every knob or button on anything 😂
