09-05-2015 05:11 PM
I have never bought a card with this much GB. But the camera wont format it. Too much GB or bad card and I'm making a trip back to the store. Please help
01-02-2018 11:27 AM
This Might sound obvious but i was having the same trouble, i kept putting the memory card in and i was getting the same error message but then i realised that the memory card was just an adapter to hold the micro card so i put the micro card in to the adapter and everything was fine from there
01-02-2018 03:35 PM
Just for the record, micro cards are not recommended.
02-06-2018 03:41 PM - edited 02-06-2018 03:43 PM
WOW, great fix, thank you !! channging the format did the trick.
05-27-2018 09:56 AM
That worked perfect. Thank you!
01-25-2019 09:57 AM
This worked like a charm... Now able to use a 64g card...Thanks!
