10-20-2016 05:52 AM
i have Canon 500 D its stop shooting pics, blinking busy msg on secreen
10-20-2016 09:42 AM
Did you try a new card? Make sure to format it in the camera. And don't use an adapter with a micro-card, use a full size card.
10-26-2016 06:08 AM
no its already in camera, no new card used, camera is not focusing pic, Autofoucus is not working properly on this lens, on other lens Auto focus is working good.
10-26-2016 09:35 AM
If it is the 18-55, there is a "fix" shown elsewhere on this site.
10-28-2016 01:57 AM
can you plz explain where i can check "fix"
10-28-2016 08:53 AM
@asimshafiq wrote:can you plz explain where i can check "fix"
Check out post #3 from Julius, Canon Product Expert.
http://community.usa.canon.com/t5/Lenses/Autofocus-not-working-18-55mm-lens/m-p/138114#U138114
Some people reported that it did not work. Most tried it again, but with a little more courage and force, and it did work.
Read the symptoms of the problem described in that thread carefully. The procedure that Julius describes is intended to cure a VERY specific set of symptoms in a lens. The most pronounced symptom is that the lens rattles when shaken.
