EOS Utility hidden videos on macOS
hpaco
Hello,
I have been breaking my head since last wekeend as EOS Utility is not working properly on Ventura MACOS, But all begun because my videos were "missing" on my external disk where I download images/videos from my camera.
Turns out videos are being downloaded but they are stored as "hidden files" on my external disk, I have to press a few keys each time I want to "reveal" those files. Only videos are hidden, JPEG and RAW photos show normally.
Does someone know why is this happening and how can it be solved?
Google shows me completely unrelated info when searching for hidden files on macos.
Help would be greatly apreciated.
Don't know why I didn't think of this yesterday, but to unhide all files with the same extension at once, do the following:
  • Launch the Terminal application
  • At the prompt, enter in the following (but don't yet press Return/Enter)  Note that <space> won't be typed in literally, ensure you have a single space after "nohidden":
    • chflags nohidden<space>
  • In Finder, locate the folder that contains your hidden videos.  Click once to select it, then drag and drop that folder onto Terminal.  This will append the path to your command.  But, don't yet press Return/Enter.
  • Press the "delete" key once.  This is to remove the trailing space that was put there after dropping the folder.
  • Now enter in the following and press Return/Enter:
    • /*.MP4
Or, enter in /*.MOV
i.e. whatever your video file extensions are.
Example full command (I have a "Canon" folder on my external "Scratch" volume):
chflags nohidden /Volumes/Scratch/Canon/*.MP4
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
9 REPLIES 9
rs-eos
That definitely sounds like a bug in Canon's utility (changing the file's metadata to have it be hidden).
Hmm... having written that, I do wonder now if the files were even correctly copied over.  I'm thinking that the software may be starting to copy the video files (and setting them as hidden), then once the copy is complete, it will unhide them.
When you use Command-Shift-. to temporarily unhide them, do any of the video filenames start with a period?
If they start with a period, they will always be hidden.   But hopefully they don't have such filenames.  You can then perform the following (note that I don't know yet how to unhide every hidden file at once within a folder)
  • Now press the forward slash key "/" and then press the "tab" key.
  • A listing of files in the folder should be shown.
  • Finally, after the "/" you typed above, start typing the file name of what you want to unhide.   Then press Return or Enter.  That file should now be unhidden.
Ricky
Thank you for your help.
Name files shows correctly after unhidding them. I'll try your steps but I see they have to be made file per file.
I´ll try to get hold of a windows computer to download the files in the future. =(
    • /*.MP4
Or, enter in /*.MOV
Ricky
Thank you, yes I can unhide all the videos on a single folder.
Hopefully they fix the EOS Utility app soon as it still hides all the videos I transfer and have to manually unhide them.
Its not working for me for some reason.
this what it gives me when i type in the prompt
"zsh: no matches found: /*.MP4"
Did you find the location (folder) to search and drag that in Terminal?
Or, you can manually type in the command along with the path as I showed in the example in the solution.
Ricky
yes i did.
I typed: chflags nohidden /Volumes/BackupDrive/Pictures /*.MP4
If it fails to find any files, then there are either no MPEG-4 files there (with extension .MP4), or you don't have the correct permissions to view the contents of that folder.
What happens if, in Terminal, you navigate to /Volumes/BackupDrive/Pictures/ and then do:
ls -alF
Do you see any .MP4 files listed in there?
Note also that this command wouldn't recursively process files in nested folders.   To do so, add in a "-R", but be careful when doing that.   e.g. to change the hidden properties of any .MP4 files in the main folder provided as well as all its subfolders:
chflags -R nohidden /Volumes/BackupDrive/Pictures /*.MP4
Ricky
It worked.
I removed (*) from the written command and it worked.
Many thanks.
Enter for a chance to win!
April 20th-28th
