eos utility dual import with 2 cards
rvd1000
Hi there,
I just updated the 5d mar IV with an extra card, so that it now has 2 cards installed.
I set up the cards so they work as backup (the 5d saves the same image to both cards).
My issue is when plugging the 5d into the usb and eos utility opens and I import new images: it imports each image twice (once from each card, and with unique file-names, as if it was 2 different images).
Is there some way I can change this behavior, such that eos utility will import only from one card automatically and skip the duplicates on the other card?
Basically I would like the import to behave similar to how it did when using one card only. I only use the second card as a safety backup, so I am not sure why it saves the same image to both cards as if they were 2 different images (I expected it to save the snapped image to both cards using the same file-name on both cards, and then only import the image once.)
I have looked for settings in eos utility to set this behavior but can't find any.
On the 5d I set it to record to multiple and playback from slot 1.
Any tips on how to avoid importing the duplicates from the second card when using auto-import in eos utility?
I can't be the only one having this issue, one would think....
Thanks!
Not sure what the problem is. Just select the card you want to download from:
20 REPLIES 20
It's the end of 2022 and still no option to select automatically download only from the 1 card. Shame.
It's a matter of automation. With the one card only you can select to start EOS Utility and automatically start downloading as soon as the camera connects to the PC. With the two cards, you need to do this manually or deal with double space and time needed for download. Additionally if you keep RAW on one card and JPG on second, the tool will rename the file to Photo.raw and Photo_1.jpg what result in no raw+jpg grouping in the DDP or LR. Original files on the cards are Photo.raw (card 1) and Photo.jpg (card 2) so obviously the EOS U tool renames the files from the second card.
I think this is the best way to work around this 'feature'. Thank you!
Waddizzle
Okay, as you say. I still say that it found your primary file and a backup file. So, it downloaded both.
I said the same the whole time, Waddizzle.
The point you are missing is that no one wants to have these kind of duplicates created on their PC...
This sounds way over complicated.  Multiple solutions have been offered.
Waddizzle - Downloads primary and back up correctly (As designed)
John - Select the card you want to D/L from
Me - Remove a card before connecting the camera (Takes an extra 6 sec), or use a card reader) what I do anyway
The utility doesn't know what your shooting configuration is.  Nor should it need to.  Duplicate, Start card A, go to card B when full, Copy RAW to card A and .jpg to card B, etc.  This behavior is as designed and perfectly normal.  The duplication thing is 100% avoidable by taking the card you don't want copied out before connection.  You'd have to select the behavior somewhere, either in the program or by removing the card.
If its that important to you, and you want it considered in a future release of the EOS Utility, please make a feature request.  Support portal > [+]Feedback > Product.
~R5 C (1.0.2.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It
The most obvious solution is to SELECT the files you want downloaded, instead of using the “automatic” download feature and complaining about the results.
Thank you.
rvd1000
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
