Why is there no 2.35:1 or any widescreen aspect ratio in Canon cameras?
anosamp
Hello, I've been wondering and being jealous at the same time for other companies, why there is no 2.35:1 or any other widescreen aspect ratio overlays when shooting a video? Only the standard 16:9 and who knows what else they have that nobody uses. I mean it would be a so simple firmware update yet so precious and important for some of us. I just don't wanna mess with tapes and other DIY unprofessional looking stuff on my cameras in professional environments. Does somebody know a way how to achieve the look I want? And no, I will not crop my footage in post, because I'll loose a lot of information from my footage, I simply want to frame my shot from the beginning to make it look proper in widescreen aspect ratio..
4 REPLIES 4
rs-eos
Is your goal to end up with 2.35:1 footage, but without cropping?  The only way I can think of doing that is to use an anamorphic lens.
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
Tronhard
As a non-videographer, can you explain what the benefit is of this particular aspect ratio?  I was under the impression that the R5c has a lot of specific setting for video, does that not qualify?
cheers, TREVOR
Before you ask us, have you looked in the manual or on the Canon Support Site?
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
AtticusLake
Rising Star
I think you're conflating different things here. Also you haven't told us what camera you're using, or thinking about, which makes it hard to get specific.
On the R5C, and I guess all the Canon cine cameras, there is. See manual page 96 -- you can overlay aspect ratio markers for any aspect ratio you want. For cameras with the photo operating system, like the R5, you may be out of luck. Of course many external monitors can add aspect overlays.
Are you claiming that nobody uses 16:9? I think a few people may disagree. Me, for one.
This is baffling. Aspect overlays just guide your framing; they don't change the fact that you need to crop in post. Same as putting tape on the monitor. And why would that be a problem? If you're doing any kind of editing, cropping is simple -- just make your editing movie the aspect ratio you want, and position your footage in the frame wherever you like.
Also, I think you're missing a real benefit here. If you shoot "taller" than your final movie -- say you shoot 16:9, for a movie that will be 2.35:1 -- then in post, you can move the footage up and down within the final frame. One project I'm editing right now does exactly this. Because it was shot 16:9, so I have more height than I need, I can move the rushes up and down to align the characters' eyelines -- super useful.
I don't know how you think this works, but I suspect you need to rethink. You seem to be saying that if the camera read out a 2.35:1 ratio directly from the sensor, you would not "loose a lot of information from my footage". But, uh, yes, you would, because the camera would only be reading part of the sensor. This would produce EXACTLY the same result as cropping in post.
Or maybe you're saying that the sensor itself should physically be wider -- like instead of 4096 × 2160, like the C70, it could be 4096 × 1750. Which is true, but this is fewer pixels -- which again would achieve EXACTLY the same resolution as cropping in post. Maybe you would say OK, go to a more dense sensor, like 8192 × 3500. Which you can do, in fact, by using the R5 or R5C. The fact that there are extra pixels on the top and bottom -- because the height is actually 4320 -- doesn't mean that you're losing information.
Bottom line, since the image circle produced by the lens is a circle, taking pixels off the sensor to make it a wider aspect ratio would really be throwing away potential information.
Then again, as Ricky pointed out, if you really want to go wide, shoot anamorphic.
While not a videographer, my first thought was that the R5C was what the OP should be looking at.  Thank you for your information, which has shed some light for me on an area in which I have no expertise!
cheers, TREVOR
08/18/2023: Canon EOS R5 C training series is released.
CR-N700 - Version 1.2.0
CR-N500 - Version 1.3.0
CR-N300 - Version 1.3.0
CR-X300 - Version 1.1.0
06/30/2023: New firmware version 1.0.5.1 is available for EOS-R5 C
EOS R6 - Version 1.8.2
EOS R7 - Version 1.3.1
EOS Rebel T7 - Version 1.2.0
EOS R5 - Version 1.8.1
