07-31-2023
03:10 PM
12:34 PM
I have this old camera that still takes great photos at 3.2mp. I’m having a problem with the mode dial. The ridges around the perimeter of the dial are getting soft and leaves black on my fingers when turning the dial. Does anyone know of anything I could apply to firm them up.
I really should upgrade to something more recent but it still works great.
thanks Mark
07-31-2023 08:19 PM - edited 07-31-2023 08:19 PM
07-31-2023 03:32 PM - edited 07-31-2023 03:32 PM
Sometimes using a rag dampened with isopropyl alcohol to wipe the rubber part will help.
07-31-2023 04:37 PM
Bought Canon EOS 30 (Elan 7E) last week. The grip was sticky and my hands became all black. I used isopropyl alcohol and wiped the rubber part. As new.
I recommend using isopropyl alcohol as well.
08-01-2023 11:55 AM
The alcohol may even dissolve/remove the rubber. Then you eliminate the problem.
08-01-2023 12:07 PM - edited 08-01-2023 12:08 PM
Did someone change the title from D30 to 30D?
08-01-2023 12:09 PM
Yes, Our camera is the EOS 30D, so one of the moderators corrected it in the title!
08-01-2023 12:25 PM
30D has 8mp, D30 3mp.
08-01-2023 12:36 PM
Oops! We changed it back to the EOS D30. Most of our digital EOS models have the D at the end of the name. People mistakenly putting the D at the beginning of the name is so common, we usually correct it without giving it a second thought. Thanks for catching this for us!
08-09-2023 12:00 AM
Thanks I’ll give that a try and report back.
