07-17-2015 02:52 PM
The Led is partially burnt out inside my Canon 6d view finder.. any suggestions?
07-17-2015 05:12 PM
Those are actually called 7 segment displays. Each segment is an individual LED making the number 8. It' probably a bad connection or a burnt out IC.
07-17-2015 05:23 PM
Any idea how to repair/replace it and how much to replace it??.... do I need to sent back to Canon?
07-17-2015 06:38 PM - edited 07-17-2015 06:41 PM
I supect that display is a component on a circuit card meaning all the 7 segment displays are soldered to a common board. Unlikely you could fix it yourself. Just getting to the board would be very hard by looking at my T6i. I'd send it in that way if it's not the circuit board and something else you know it's going to get fixed and not you just changing parts. I work on robots for a living and I wouldn't even attempt to repair that myself.
07-20-2015 01:44 PM
Thanks, I'll send it to Canon for repairs.
