07-21-2022 08:59 AM
Looking for an all-around single lens for my old Canon 30D. Primary use is for wildlife and bird photography. Saw the Tamron 18-400mm f/3.5-6.3 Di II and with the range from wide-angle to tele it looked like it might be a good choice. Will it work with my 30D though?
07-21-2022 09:13 AM
Yes it will work, but it is pretty big and heavy for a walking around lens. I prefer my 18-135 for walking around and my 70-300 or 150-600 for telephoto. And 18mm is not particularly wide angle on an APS-C lens.
07-21-2022 09:31 AM
Thanks - I've been using a Canon 70-300 which does OK as a tele, but I thought the wider range of the Tamron would be an advantage at both ends of the spectrum.
07-21-2022 10:26 AM
Buy one of the 150-600mm super zooms. Way more better than that Tamron 18-400mm f/3.5-6.3 Di II. Do you not have any other lenses for the old 30? If not get one of the 18-55mm standard zooms. Way, way better idea!
If you are in a situation where the 18-55mm will do the job you don't need the super tele and if you are "bird" shooting you don't need the 18-55mm. So both should work very nicely together. 😊
07-21-2022 11:28 AM - edited 07-21-2022 11:30 AM
What lenses, if any, do you currently own?
[EDIT] I do not feel that Tamron 18-400 is a good investment for the price. Look elsewhere.
07-21-2022 04:23 PM
I have 3 lens - Canon EF 50 1.8, Canon EFS 18 - 135mm, and the Canon 70 - 300. Which of the "super zooms" might I find used for less than $800?
07-21-2022 04:45 PM
You might find a Sigma 150-600 Contemporary lens on sale, or a Tamron unit of the same FL range, used or refurbished as some folks move from the EF lens system to the RF mount.
07-21-2022 05:02 PM
Nice lens arsenal.
Zoom lenses have what is known as a “zoom ratio”, which is the ratio of the longest focal length to the shortest focal length setting. The high quality zoom lenses tend to have zoom ratios around 3:1, give or take a little.
A “super zoom” lens tends to have a zoom ratio well in excess of 10:1. The Tamron 18-400 has a zoom ratio that is well over 20:1. In order to achieve such a wide range of focal lengths the lens engineers have to make compromises and cut corners. One of the first things to go on the chopping block is image quality.
A “super telephoto” lens has a focal length in excess of 300mm. Your 70-300 would fall into the category of “medium telephoto” lens. Your 18-135 is pushing the envelope of what defines a “standard zoom”, like a 24-70mm.
07-21-2022 06:56 PM
Thanks - will look for a Sigma 150-600 that's in my price range
07-22-2022 10:13 AM
"... will look for a Sigma 150-600 that's in my price range"
Also the Tamron 150-600mm. They are near identical twins so go with the one that offers the best deal. Sell the 70-300mm zoom. It's not even in the same zip code as the Sigma or Tamron zooms.
