04-17-2014 02:13 PM
I printed some pictures from my t2i at sams and the pictures where cut off. Like full body shots that I took the head and feet were cut out when trying to 4x6 prints. What do I need to do make the whole picture fit without cropping.
04-17-2014 02:30 PM
Print preview?
04-17-2014 02:34 PM
This is what happen I took pictures for a friend's party. She took the sd card to sams club to print. The pictures look okay on my computers the heads and bodies were all there. I will print preview later and let you know.
04-17-2014 02:53 PM
Sounds like they were printed in landscape mode but shot in portrait mode OR cropped improperly just before making the print. Although it's a bit of a different style of topic see message 15 here.
http://www.rccanada.ca/rccforum/showthread.php?t=147971&page=2
04-17-2014 03:45 PM
@aintmy4ult314 wrote:This is what happen I took pictures for a friend's party. She took the sd card to sams club to print. The pictures look okay on my computers the heads and bodies were all there. I will print preview later and let you know.
If you had someone "professionally" print them then I'd take them back. They should know how to print a photo and not crop it, and they shouldn't charge you for their mistake.
04-19-2014 04:05 PM
The camera takes photos with a 3x2 aspect ratio. If you print in a size which does match the aspect ratio (e.g. a 5x7 or an 8x10 for example are not 3x2 aspect ratios) then the image needs to be cropped to the size print you plan to use.
04-20-2014 03:25 PM
I figured it out I crop the picture before I went to print which messed up the picture ratio. It's good now thanks for the help everyone.
