Setting custom white balance with 80D and white card
alainb
First i want to say hello to all of you there. This is my first post on the forum
I recently bought a 80D for making video.
I just got myself a portfolio colors checker tool for setting my custom white balance.
On the internet they talk about a square dot zone to make the white sample from the card. I do not see that zone on my 80D.
Can someone tell me how the camera find the white zone or how to turn that dot zone on, on the 80D?
Thank you
EOS 80D
TCampbell
You're probably over-thinking things a bit.
When you use a custom white balance, you take a photograph of something that should be "white" if the light source is also white.  Most light isn't pure "white" and has a bit of a color-cast to it... possibly causing things to look slightly yellow or orange... or blue ... or even green.  Anyway, if the camera knows that the object being photographed is supposed to be pure white. then it can look at the pixel values and notice that... there's a touch too much 'blue' in them... and it can adjust to compensate for the color cast.  Having done this using a target sample, and knowing that everything else you shoot is in the same light, it realizes it would need to subtract the same amount of 'blue' from every pixel in every shot you take.  That's the point of white custom white balance (and as soon as you changing lighting conditions to some other light source, you have to re-shoot the custom white balance frame.)
The easy solution is to just get close enough to the white balance target so that it fills the entire frame (corner to corner).
But the point in showing that example (showing a region with a giant rectangle made with those dotted lines) is to show that the white balance target doesn't really have to fill the entire frame... but it does need to dominate that area in the center.
The pattern of small boxes you see is simply an indication of where all the auto-focus points are in your 80D camera (when shooting through the viewfinder... not live-view mode).  Those focus points are there whether the boxes are drawn or not.
To change focus modes, you normally press the AF pint selection button (that's the upper-right coner on the back of the camera) and that lets you change AF points within your current AF area.  But while in that mode, you can press the tiny button in front -- near the shutter button -- and that lets you change AF areas (that's how you toggle between modes such as single AF point, surround, full auto-select mode, etc. etc.)   This is covered starting on page 114 of your manual.
Make sure you read your manual on how to do set AF areas and AF points.  You can find all the manuals here:
https://www.usa.canon.com/internet/portal/us/home/support/camera-user-manual
Tim Campbell
5D III, 5D IV, 60Da
16 REPLIES 16
kvbarkley
Did you bother to read the manual? It is all discussed there. You might need to download the full electronic version and not the basic one that comes with the camera.
Thanks for the answer.
I did bother to read the manual. At page 164 they show the square dot zone i am talking about. I do not see that square zone in my viewfinder when taking a picture for my white balance..
Any idea why?
EOS 80D
Any idea why?
What shooting mode is the camera in?  Basic modes display limited menus.  Change it to [P] mode.
I shoot in manual but i tried it in  all modes... same things. Smiley Indifferent
 this is the square dot view i am refering at:carré balance blanc.jpeg
EOS 80D
I am not familiar with that image, or what info it is trying to convey.  It resembles the 45 AF points in the 80D, but the heavy, dotted line is not something that you will see in the viewfinder, nor Live View.
well, it is also show in the manual of the 80d
EOS 80D
The AF points have little to nothing to do with White Balance.  I suggest that you continue on as if they are there, and simply take a shot of the calibration card.  It is the color of the card that is most important, not how well it is focused.
What do you see in the viewfinder?  Have you checked your AF settings?
I'm no expert on custom WB, so consider the source. But I think they may mean that the item you indicate as being pure white (i.e., the card) has to fall within the indicated area.
Bob
