05-03-2023 06:21 PM
I am trying to reset my Rebel T6 to original factory settings and I go to MENU, then 3rd Wrench and where it should say "Clear Settings" it does not exist, only WIFI enable/disable. Any help as to what I'm doing wrong? Sorry for the poor photo.
Jim
05-03-2023 06:26 PM
The camera can only be factory reset in the creative ie (M, Av, Tv & P) modes. Full Auto and other Basic Zone settings do not show the whole menu system.
05-03-2023 06:26 PM
05-03-2023 06:43 PM
Thank you. You are correct of course. Now it says Busy...Please Wait. Is this normal?
Jim
05-03-2023 06:48 PM
Does the camera just continue saying busy.
05-03-2023 06:55 PM
Yes, 5-6 times for the last 15 minutes.
Jim
05-03-2023 06:57 PM
So you're saying when you set "restore to factory" the camera stays stuck saying "busy".
05-03-2023 07:05 PM
Just tried again and still says "Busy...Please Wait"
Jim
05-03-2023 07:10 PM
Remove the lens & memory card. The try to reset the camera.
05-03-2023 07:40 PM
Removed memory card 1st, same result. Then removed lens, same result. Here is a photo of what it says, "Busy...Please Wait" Sorry for blurry photo, I tried many times, but I only have 1/2 second before it blinks off.
Jim
05-03-2023 07:42 PM
Have you tried resetting the camera with both of them removed. Why exactly do you need to reset the camera.
