07-10-2017 03:44 PM
07-10-2017 04:27 PM
You might try a new card, too. If the good sectors are fragmented, it might take extra time stuffing little pieces of your files here and there in the card.
07-10-2017 09:51 PM
The red light typically indicates that the camera is using (or at least trying to use) the memory card. If the card is having issues then it might explain the symptom you've described.
If you do reformat the memory card, make sure you tick the "Low Level" checkbox.
But you might just consider buying a new memory card. I don't trust my photos to memory cards once they show any signs of having reliability issues.
07-10-2017 04:01 PM
Have you tried formatting the card in the camera? Choose a low-level format.
07-10-2017 04:09 PM
07-10-2017 04:27 PM
07-10-2017 06:46 PM
@Lindseymiller56 wrote:
No I believe I have not. What would be the purpose
You format the card so that camera can FULLY initialize it properly. New cards may seem like they have been formatted, but they have not. What you are seeing is residue from production testing, not not a fully formatted storage media.
With a T3, only use full-size SD cards, 32 GB or less. Avoid micro-SD cards like the plague. They don't work.
07-10-2017 09:51 PM
07-12-2017 03:23 AM
07-14-2018 02:35 PM
