Search instead for
Rebel T3 Lines on viewfinder and photos
Kim1
So, this is happening to all my photos. These lines appear in even in the viewfinder. I've tried different memory cards, but it doesnt help and I am at a loss. Has anyone ever seen this before and can this camera be saved? Help?
13 REPLIES 13
Waddizzle
In the both the viewfinder AND photos???  The only thing that's really in common with those two scenarios would be the lens.  Try a different lens, if you can.  Otherwise, you need to contact Canon Support, 1-800-OK-CANON.
Unfortunately it happens with my other lens too. Its very weird.
Let us get this straight.
Do you see this in the *viewfinder* or on the *LCD screen*
Sorry - your'e right - its the LCD screen. Any ideas?
I guess bad row/column circuitry from the sensor to the rest of the electronics. Call Canon to see how much it will cost to fix.
If you really want to use this camera for a while you could try shooting at M instead of L for reduced resolution.
The low color saturation, assuming it isn't intentional, suggests an even broader circuitry problem. Did the camera get wet or something?
Bob
chuck1978us
Did you ever get the problem fixed? my T3 just started the same thing
If you see the issue in photos, then your camera needs to be repaired.  If it is only in the LCD screen, your camera may still need a costly repair.  But, if it is not affecting photos, you may or may not want to spend the money to fix it.
I suggest that you take note on where the problems appears; viewfinder, LCD, and/or photos, and call 1-800-OK-CANON.
