12-13-2024 02:32 PM
Hello,
purchased my R8 in Dec 2023 and I was very excited.
In Oct 2024 with my wife went Barcelona and few other European countries.
I took R8 with RF 24-105 4-7.1, RF 24/1.8 STM and RF 35/1.8 STM
The weather was nice and sunny, I set my R8 to Tv mode, 1/320, aperture wherever it falls, EV 0, AUTO ISO 100-200.
I took 1,800 RAW images for the entire trip and to my surprise 90% of the images were underexposed and they look dim and dark when I imported the RAW files in Capture One PRO.
Even when I use R8 with Godox TT350c indoors, the images are too dark and contrasty.
In the Picture Profile, I use Standard and lowered the Contrast to -3, still dark and contrasty images.
My wife has a chepo Nikon Zfc and when we take photos at the same subjects, same lighting, same setting everything the same, her images are brighter, properly exposed and more pleasing to our eyes.
Is there a setting or something I can adjust, so I can get properly exposed images in Tv mode and in general, so I can start loving my R8 ?
12-13-2024 04:15 PM
Can you put RAW images in a file sharing service such as Google Drive. So we can look at the metadata attached to each picture. Were you taking these pictures with flash or without. If so were those pictures with a Godox speedlite they’re NOT compatible with the EOS R series.
12-13-2024 04:27 PM
These pictures I just took are without flash. Godox TT350c is compatible with EOS R8.
12-13-2024 04:32 PM
It’s not fully compatible with the EOS R series. That speedlite causes EOS R series cameras to lock up all the time in low light. They also underexpose pictures too and some other issues going on. Are these pictures underexposed still in Full Auto without flash. There are some scenarios where you have to add Exposure Compensation (EC). Especially when it’s sunny the camera will underexpose in that situation.
12-13-2024 05:27 PM
My Godox TT350c is FULLY compatible with my EOS R8.
My Godox TT350c NEVER locked my R8 in low light.
NONE of the pictures I posted were taken using flash.
Increasing EV to compensate for underexposed image in Tv mode does not do anything because the Tv mode will compensate for the increase.
12-13-2024 05:32 PM
Are you using Auto ISO?
12-13-2024 05:37 PM
Yes, AUTO ISO 100-800
12-13-2024 06:22 PM
If you manually set an ISO . Then you dial in EC then you override the camera’s exposure choice. What lens or lenses are you using on the camera. Now the flash incompatibility is something different. The speedlite’s AF Assist Beam will lock the camera up. If the camera is set to One Shot and the camera can’t lock focus in low light. If the ambient lighting is inadequate for the camera to AF. The camera will use the speedlite for AF Assist. But the Godox speedlite doesn’t understand modified AF Assist Beam signal from the camera. Causing the speedlite to fire a pre-flash and cause the camera to lock up. Canon’s EOS R series cameras use Intermittent Flash to focus in low light. But 3rd Party speedlites don’t support that. All of Canon’s speedlites do. The old school IR AF Assist Beam is INCOMPATIBLE with ALL mirrorless camera systems. Note the beam is NOT IR. It’s just a red grid pattern aligned with AF sensors in a DSLR or AF SLR.
12-13-2024 05:34 PM
Let’s leave the flash question aside, for a moment.
Look at the picture that shows Tv mode used and look at that Histogram and let’s try to determine why the exposure is to the left of the middle point.
