01-12-2024 12:27 PM - last edited on 01-12-2024 12:37 PM by Danny
First post, new here. Curious, but does Canon read these comments?
I just purchased an R6 Mark II and I was shocked that the camera's display was disabled when external HDMI was connected! My camera shop was also baffled by this. My vision isn't what it used to be and I was excited about the ability to use a larger external display for monitoring while also having the built in screen's touch focus and info.
If it's possible, I would really appreciate the ability to connect an HDMI monitor while maintaining the ability to record to the camera and use the camera's display in both photo and video modes.
03-04-2024 03:31 AM
Yes. And it needs to be changed.
It's limiting and camera is disfunctional, which seems to be Canon's motiv.
Thanks, you too.
03-04-2024 06:00 AM - edited 03-04-2024 06:05 AM
@luka3rd wrote:Yes. And it needs to be changed.
Thanks, you too.
If that is what you need, then I suggest that you upgrade to a cinema camera. BTW, during movie playback there is only ONE signal source being routed to two outputs. Most cable TV boxes can do something similar.
It has been clearly explained to you. The camera has only set of electronics capable of creating a video signal.
Most owners of the camera are only shooting stills, not videos. Including a second set of electronics to create a second video source would significantly raise the cost of the camera with a feature they would most likely never use.
So, if they can send one signal in two directions, then why don’t the do it when the camera is in “Clean HDMI” mode?
My guess is that people would start complaining about the lack of AF points and and camera controls on the rear screen. In other words, we are back to square one…the need for a second video signal source.
03-04-2024 06:15 AM
It's been clearly explained?
No, it's been covered up with nonsense, sorry. But the talk about two circuits is bogus...
I thought we are all here to influence others for the best!
And your aim is to defend Canon and their decision no matter how malicious they are!
I don't need cinema camera, I need functional modern MILC, what R6 II is supposed to be!
Giving micro hdmi and useless hinged screen is where the surplus earnings should stop.
Blocking horizon level and other functions of the hdmi port are pure negligence.
03-10-2024 11:00 AM - edited 03-10-2024 11:01 AM
Hello Waddizzle,
This is a debate that has no place.
"I suggest that you upgrade to a cinema camera"... This is what we undoubtedly heard a few years ago with focus tracking or dual cards or histograms, fast colors etc...
Send a signal in two directions, other brands of the same caliber of devices do this. Canon will do it, they're just late. For our inconvenience.
But we had hoped that they would correct (evolve) quickly.
Don't see it as a complaint, but rather as a legitimate desire.
03-10-2024 05:51 AM
All the same!! Will the Canon team announce a software update to allow the use of an external monitor AND the camera's LCD? We hope so soon! other brands do it.
03-10-2024 01:46 PM - edited 03-10-2024 01:49 PM
@David2024 wrote:All the same!! Will the Canon team announce a software update to allow the use of an external monitor AND the camera's LCD? We hope so soon! other brands do it.
Nope. It is not a firmware issue. The camera lacks the electronic hardware to do it.
I suggest that you read through all the comment in the thread. A firmware update will not add electronics to the camera body so that it can produce two independent video signals.
Let me put it this way. Some cable TV converter boxes could display a “picture in picture”, while most could not because they lacked a second cable signal decoder to do it.
Have a nice day.
03-10-2024 02:32 PM
My problem was mainly to find a monitor that could communicate with the camera on the autofocus via touch as on the LCD. And I didn't find.
03-10-2024 04:36 PM
@David2024 wrote:My problem was mainly to find a monitor that could communicate with the camera on the autofocus via touch as on the LCD. And I didn't find.
Use an iPad and the Canon Connect App.
03-10-2024 06:25 PM
Yes I use Canon camera conect with my Iphone in wifi mode. That’s already it, you’ll tell me. It's true, but the image returned by the application is not much larger than the LCD and the functionalities are basic. I can't change the ISO or the aperture for example. It doesn't broadcast zebras either.
On the other hand, and this is a very good thing, the app allows you to follow the focus by touch like on the canon.
I invested in a pocket transmitter (acssoon nano, which I attach under my Canon mounted on the DJI RSC3 and which wirelessly retransmits the image) and when I stream, not recording internally, I can benefit from the iPhone via the Acssoon nano application which is very good and in addition to the Canon Lcd.
But I imagined being able to take advantage of this ergonomics as a monitor when I record internally too. In the end, it won't be possible this way.
We always want the most, don't we?
06-28-2024 09:51 PM
If you aren't going to be helpful no reason to keep repeating the same misinformation. That fact that it CAN export an hdmi video feed and keep the screen on is clear--however in this mode it won't record the internal cards (which for some is a deal breaker). So it's not a "hardware issue" as you keep wrongly repeating. The camera can put out a signal over HDMI AND keep the screen on, but it forces you to record on the external HDMI source.
Also, "most people use this for photo" is just blatant fabrication. The video capability of this camera is well documented and you have no idea how users are leveraging it.
I too am interested in this discussion and miss by Cañon--I use a Raven Eye and love the functionality but by turning of the screen I lose all access to auto the ability to touch focus etc. This complicates the workflow and is frustrating--unless I hook up to a Ninja and record that way.
