10-06-2020 10:09 AM - edited 10-06-2020 10:12 AM
On the R5 camera, how can you display the focal length of the lens, on the EVF or rear screen, as you change it while zooming?
Thank you!
10-07-2020 07:28 PM - edited 10-07-2020 07:28 PM
So what? If the focal length changes as a function of focus distance by a sufficient amount, then a program could take that into account and update the value shown.
Either way, I *repeat* again, it's still better to have something shown for the zoom focal length on the screen instead of having *nothing* shown on the screen. My Olympus camera did it quite well, and I was happy with it. Canon doesn't show it and doesn't give you the option to show it if you need it. But they do show a ton of unrelated junk on the screen that really has no value to me at all and they don't give me a choice to not display that junk on a single item by item basis.
10-06-2020 01:34 PM
@usern4cc wrote:I just talked to Canon support. They have *no* way (currently) to display the focal length of the lens in either display. I have explained my reasons (below) why it's important and asked them to pass it on in hopes of adding it to a future firmware update (but I'm not holding my breath on that one).
That's very sad - even old little companies like Olympus (my previous camera system) displayed the current focal length as one of their "important" displays - which it is.
When I do panoramas on a tripod with ball-stop settings, I need to know the actual focal length of the zoom lens so that I can choose the proper step distance for the ball-stops to get the proper spacing for the panoramas. This is an important thing.
If I was making movies with the R5 (which I'm not), I might want to know how to set the exact focus positions so that I could do predefined or repeated focus pulls or whatever other video magic they like to do.
Sounds like a good time to use a prime lens, instead of a zoom lens.
I'm curious. What type of Olympus camera was this? Did it have interchangeable lenses? There is one major potential problem with your suggestion. What about third party lenses that do not report correctly? And, there are a lot of them out there already that do not report their focal lengths correctly. Some will even identify themselves as Canon lenses.
10-06-2020 02:33 PM - edited 10-06-2020 02:49 PM
I have nothing against using prime lenses. The main advantage of a zoom is that I can walk around with a single zoom lens which covers most of what I want to cover for walking around landscapes, while still allowing me to choose a particular focal length to do a particular panorama with the same lens. When Canon comes out with more choices of primes that fit my needs I will probably get a few just for taking panoramas. But until then I'll use their RF 70-200 f2.8L IS for that.
Previously, I used an Olympus EM1_II, with their 12-100 f4 pro lens (24-200 f8 FF EQ). I could set it around 100mm (FF EQ) to take a good panorama, or around 135mm to take a really detailed pano (I'm talking a giga-pixel panorama or so here). It showed exactly the focal length in use so I could confidently get it where I wanted it so I could set the ball stops for the step size I wanted (I've taken some panos with up to 200 positions in the pano reliably set with ball-stops in both width and height).
As far as 3rd party lenses, if they transmit bad data about focal length then too bad for them and for the buyer who bought them. You live with what you buy, so why complain if you get extra information given to you that you didn't have before? If they identify themselves as a Canon lens then, again, you get what you pay for (cheap in, cheap out).
As it is, my very expensive R5 and RF 70-200 f2.8L IS lens can't report something as simple as the zooms current focal length which the lowly $1K or so EM1_II and $1K or so 12-100 f4 pro lens can reliably report. Too bad, Canon - maybe you should think about adding this in a future firmware update. After all, I'm quite happy with the really great quality of the images it provides, but they sure do have a few holes in their menu system features that should be examined, re-thought out, and fixed in future firmware updates.
06-25-2023 08:38 PM
All of my Olympus camera had this feature, even the current OM1.
12-20-2021 10:25 AM
I too am frustrated that the focal length is not displayed. I am really taken by surprise with this issue.
12-20-2021 10:44 AM
After more than a year, they have NOT fixed this simple ommision with a firmware update. Yes, you can take a photo and open it up and toggle to the screen to the version that shows the focal length for the photo taken, but this does NOT tell you the focal length before you take the photo. I often take panoramas and want to use an exact focal length so I can have them stitch perfectly, and to do this I need to adjust the zoom according to a display focal length to get it correct, and I can NOT do this due to Canon's ommision of this sorely needed displayed information.
03-03-2022 06:44 PM
usern4cc,
I hope they reconsider. I use it all the time in my Olympus OM1.
I often try to match a prime, or do lens tests and like to "bracket" fixed points on the zoom.
I am ok if they just display the value from exif. It is recorded with image. Not sure if exif is passed through on focus though. You would think so since they have to apply lens corrections by focal lenght.
I am guessing that the lens correction is applied while focusing, but I could be wrong.
06-23-2022 06:33 PM
I often return to a site and repeat multiple photos from notes in a notebook, some of the notes is different focal lengths from the position, ex. the same site, repeat compositions in spring, fall, snow of winter, etc. There are many other uses, but that is one example
06-23-2022 03:48 PM
Just adding to this as I recently picked up an R5C. I had been looking for a way to show focal lengths as I zoomed and came across this thread. As with the R5, the R5C can’t do this…in photo mode. But in the Cinema menu/OS, this works by default! So it seems one team within Canon has figured this out. Time for them to share the knowledge especially with a camera like the R5C now out there.
06-23-2022 05:47 PM
As previously stated the setting of the zoom ring is not always accurate. Many third party lenses suffer from breathing when zooming.
The OP pointed out that knowing the focal length was needed for accurately compositing a panoramic image.
in my experience it is not that crucial for the final result. Things like barrel distortion tend to have greater impact. What purpose does FL serve when grading video?
Besides, I am not aware of how one would create a pano when shooting video
