12-20-2012 03:38 PM
I'm going on a 2 week trip to Japan in 3 days so I'm hoping to figure this out before I leave.
I got my new 6d with 24-105 L lens kit, and also the 70-300mm f/4-5.6 IS USM. It doesn't seem like any of the photos are that sharp without a very high contrast shot in full sunlight. Indoor shots or those with lower contrast (tree bark, leaves, something in the shade, etc.) seem pretty unsharp to me. I'm not sure if the AF just can't get a precise focus, or if the sensor just can't get good detail unless those conditions are met.
This is my first DSLR, although I've had film SLRs for 30+ years before that, and digital point and shoots for the last decade or so. I'm not sure if my expectations were too high or if there's something wrong with the camera, lenses, AF, or IS systems, or if I'm doing something wrong.
Some photos are below. I shot them all above the 1/focal length rule and some 2x or 3x or more above that, so in theory that would eliminate the camera shake issue, and also in theory the IS system should give you 2-3 stops so it doesn't seem to me that camera shake should be the issue. (I've also taken tripod shots and had the same issue so I don't think it's camera shake.)
All are large fine jpegs (20mb) straight from the camera, blown up to 100%.
santa1 Indoors daylight, no interior lights on, 24mm focal length, 1/30, ISO 1000
santa2 Indoors daylight, with interior lights on, 105mm focal length, 1/125, ISO 6400
santa3 Indoors daylight, with interior lights on, 300mm focal length, 1/320, ISO 10000
santa4 Indoors daylight, with interior lights on, 300mm focal length, 1/640, ISO 20000
wall1 outdoors, 105mm focal length, 1/500, ISO 100
wall2 outdoors, 270mm focal length, 1/500, ISO 100
treebark1 outdoors, 70mm focal length, 1/125, ISO 25600
treebark2 outdoors, 300mm focal length, 1/320, ISO 25600
license1 outdoors, 300mm focal length, 1/320, ISO 25600
leaves1 outdoors, 70mm focal length, 1/320, ISO 25600
leaves2 outdoors, 300mm focal length, 1/320, ISO 500
truck, 105mm focal length, 1/250, ISO 100
Other than the truck badge and maybe the wall photos (high contrast, full sunlight), most of them don't seem that sharp to me. What do you guys think? Most people are raving about how good the low light performance is on the 6d but I'm just not seeing it, not even in moderate light.
Here's a link to where someone compares a few different cameras one of them being the 6d. My images are not as sharp as them as far as I can tell.
http://www.etherpilot.com/photo/test/misc/6d_5d3_d600_colfix.jpg
Any thoughts or suggestions you can give are greatly appreciated! Thanks!
05-14-2015 01:06 PM
05-14-2015 03:23 PM
05-14-2015 04:01 PM
10-19-2015 09:39 PM
Hello there. I agree with your post. I have a 6D and find that the out of camera JPEG images are quite soft. Much softer than my previous Canon camera which is a 70D. Now for the fix, the Canon 6D takes amazing photographs but you just need to do the following.
1st, always shoot in RAW format. Even if you simply save from RAW to JPEG later it captures sharper picutres if you convert from RAW to JPEG in post.
2nd, to fix your issue if you want to shoot in JPEG as I sometimes do is all in the picture styles area. By default the sharpness is set WAY to low. I manually set my sharpness to 5 or so to get a truly tack sharp image when I'm looking for that. I hope this helps you out. I love my Canon 6D but was quite disapointed with the JPEGS until I figured out how to tweak the picture styles. Good luck and enjoy your great camera.
-Mark
