02-16-2013 09:41 PM
Currently, It will only allow me to film clips 10-15 seconds... how do I change it to allow me to film longer??
Thank you!
02-21-2013 06:42 AM
Hello Chobitsb,
Your EOS Rebel T4i is capable of recording much longer video clips. The biggest factor to consider here is the memory card you are using. Full HD video requires a higher speed card because of the large amount of data being recorded. I recommend that you use a card that is at least Class 10 rated or better. If you are using a slower card, the camera's memory buffer fills up too quickly and the camera stops recording.
02-28-2013 02:20 PM
i have a similar problem, my eos rebel t3i are automaticaly stoping when a recording full movies but in poor movie are working, my card is (sandisk sdhc 4 16gb) can u help me?
02-28-2013 10:16 PM
07-15-2013 03:10 PM
John, great info, does this mean as long as someone stops recording and re starts recording (could be done by remote I assume) every 10 minutes or so there should be no issues if using a 32 gig card, etc.....
12-07-2014 11:09 AM
I realize that this is an old thread, but I was having the same issue all of a sudden! I have figured out that somehow my settings were changed and it was on "video snapshot".
Set the dial to the video setting, then on the screen press the Q button. On the left hand side at the bottom is the video snapshot setting, to turn it off.
