01-10-2018 05:37 PM - edited 01-10-2018 05:44 PM
Just got the Neewer NW 680 primarily because of the many features for the price. Well, it doesnt matter at the moment because I cant get it to work in the Automatic Zoom mode. The diffuser and white board are fully retracted (per instuctions) but the unit remaions in manual. Per owner manual, I pressed the Zoom button several times but still no go. Any suggestions (other than trashing it)? I am using it on a 77D,
01-10-2018 06:10 PM
@tconstan wrote:Just got the Neewer NW 680 primarily because of the many features for the price. Well, it doesnt matter at the moment because I cant get it to work in the Automatic Zoom mode. The diffuser and white board are fully retracted (per instuctions) but the unit remaions in manual. Per owner manual, I pressed the Zoom button several times but still no go. Any suggestions (other than trashing it)? I am using it on a 77D,
I suggest you talk to the folks who made the flash. It is they who claim it works with Canons, right?
An even better idea would be to send it back for a refund, and get a genuine, issue-free Canon speedlite. Check out the Canon Refurbished store for deals on flashes and strobes.
01-10-2018 07:11 PM - edited 01-10-2018 07:39 PM
Make sure your flash head is pointing straight ahead (not pointing up in bounce position). On many flash units the flash head Auto zooming is disabled when not set to straight ahead.
With a Canon brand flash, when in bounce position, the flash head Auto Zoom will default to 50mm in order to have better spread of light on the ceiling. (the display will not show 50mm but shows -- instead) It is possible to set a manual zoom setting as well.
If that doesn't work, try using the camera's external flash control menu to set the zoom head to auto.
