12-26-2023 10:24 AM
Every time i try to use EOS Webcam Utility with my camera it shows error 70, i try to put my battery in and out, turn my camera off and on but it still shows and I can only use it for uses without the webcam utility. Its a big problem because i mostly use it for streaming.
12-26-2023 02:04 PM
What lens are you using? Does your lens require the use of a mount adapter? If so, is it Canon?
Did you say that you camera works correctly when you do NOT connect a USB cable for use as a WebCam?
What is computer’s Operating System version number?
Have you tried a different USB data cable and different USB ports on your computer?
12-26-2023 05:49 PM
The answer number 1 It came with the camera so yes it is canon.
2. Yes it works fine without
3. I can not find out at the moment I’ll get back to it when I can
4. again can’t try it but will when I can
and some added info it only occurred when I re-downloaded the Camera Utility..
12-26-2023 06:24 PM
Unfortunately, there aren't too many directions for you to go in.
https://support.usa.canon.com/kb/index?page=content&id=ART177668
